MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #31
Old 01-30-2007, 03:06 AM
bump
bump
  #32
Old 01-31-2007, 04:06 PM
I got my amp replaced and everything has been ok since then. I also added a cap, which seems to help the sound but, not at all getting rid of the drop in power the car gets when the bass hits hard. So, either a bigger batter, a second battery, or an after-market altenator cause the loss in power to the car is just bothering me.
Now the problem I have now is that I believe they tapped power post bose amp. Mainly to get more power to the LOC (not sure if there is volume adjustable on that one) to drive the amps better. It is loud and pretty clean from 12 to 25 volume. However, on low volume it has static. Not sure why, but after 22 it can have this mid range distortion. Like on some vocals it gets distorted as the volume goes up but only on the mid range it seems. Everything else is clear. Which IMO must be due to the EQ'n from the amp. So, now I want a new radio (HU) to get the sound I should have had to begin with. Thing is that if I go that route and change the HU, I might as well get the Navi and go all out. So I don't have to do this crap again. Such a pain. But, I love my car and I need good sound. There is just no other way.
  #33
Old 02-06-2007, 02:43 PM
mid range distortion after 22? that sounds like you probably are clipping the head unit. I couldn't see turning this up past 20 without clipping the signal.
  #34
Old 02-13-2007, 07:59 PM
andycon
Guest
Posts: n/a
FWIW, I spent a lot of time trying to find "twisted pair" RCA cables as mentioned in this post. (with open end to splice into the HU output wires....) after a lot of stuffing around, I finally realized I can just order regular twisted pair RCA's and cut them. 1 pair will provide 4channel RCA's when cut...
If others are looking...
I was installing an amp at the same time, so I got an Amp wiring kit from here:
http://www.autotoys.com/x/cust/searc...isted+pair+rca
Thought it might help others when looking for wiring and parts.
  #35
Old 03-22-2007, 04:14 AM
sfgr415's Avatar
City Situations
Send a message via AIM to sfgr415
How about hooking up a JL 500/1 only? I will do a 4 ch once I get a new HU. I should tap in pre-amp right? LOC?
  #36
Old 03-22-2007, 05:02 PM
Quote:
pacific audio oem integration. plugs right in. works good for me now that i have it adjusted properly.
  #37
Old 05-06-2007, 02:04 PM
Iam really a noob when it comes to speakers ect i see that it is possible to upgrade my speakers but all the talk about RCas ect just lost me. I have a 05 with the Bosecdchanger ect, i just want to upgrade my speakers and tweaters. Can some one recomend some for me. Thanks in advance
  #38
Old 06-29-2007, 04:43 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Send a message via AIM to BocaCoupe Send a message via MSN to BocaCoupe
Has anyone added sub/main amps to the stock bose HU and actually liked the results?
__________________
2005 DG 6MT - MREV2 - 5/16th ISO Thermal Spacer - Coolant Bypass - Z-Tube - K&N - V1 Hardwire - GTech Pro - KPTech Window Rollup - Clear Corners - High Power Leds - Phillips Bluevision Fogs - 18% Llumar Stealth
  #39
Old 06-29-2007, 05:20 PM
andycon
Guest
Posts: n/a
I have sedan that comes with bose 4spkr and sub (with amp).
I upgraded speakers (MBQuarts), upgraded sub, with amp to drive 4 speakers and amp for sub. (ditched the stock amp).
The sound is way better than the stock bose, but I do wonder what difference the HU would make - I have no comparison.
I would def do it again.
  #40
Old 06-29-2007, 08:19 PM
Send a message via AIM to vegaseric Send a message via MSN to vegaseric
I just upgraded my stereo using the stock Bose head unit and it sounds pretty good. Tapping in to the inputs to the Bose amp yields decent sound. I'm using the following equipment:
- MB Quart QSD 216 6.5" components up front (a bit bright, but the sound is clean)
- MB Quart DKD 116 6.5" 2-ways for rear fill
- JL Audio 10w3d4 10" sub in a 4080 box
- JL Audio 500/5 amp powering everything
Hopefully, I can get the Nissan OEM iPod adapter installed in the next month or so.
  #41
Old 07-10-2007, 08:33 AM
Does anyone know where exactly the speaker wire is in the trunk that you convert to RCA using a LOC? This is on a non-Bose Sedan.
  #42
Old 07-10-2007, 05:09 PM
Send a message via AIM to gametox Send a message via MSN to gametox
Hi,
I have the following:
1. DLS a6 amp
2. IDMAX 12" x2
I am only going to put in just one sub with the amp. I was pleasantly surprised to see more DLS authorized retailers. Before when I got my amp, there was like 2 in the US. lol
I have the 06 Coupe with Bose prem HU.
I am doing the install with a friend and so far we ran the amp wire (big red one) from the battery area to the trunk. Also have a remote wire from the cig lighter area (we took the console apart). I had no idea about "LOC" and now i am very confused as to what is going on lol.
Advice? TIA.
__________________
Chevy Aveo! KILL ME NOW!
  #43
Old 07-18-2007, 09:00 PM
Is there a way to bypas the stock bose amp. When I got by system hooked up they tapped into the bose amp and now bose amp gone bad. There is no sound coming out from the speakers. So is there a way to bypass the bose amp and just use my aftermarket amp?
  #44
Old 08-24-2007, 03:06 PM
How do you know which Amps will work W/o LOC
I've been looking at allot of amps, and none of them seem to mention the differential-balanced signals, or single ended terminology.
  #45
Old 08-26-2007, 03:18 PM
JL Audio
JL Audio makes amps that accepts differential-balanced inputs.
Quote:
Tags
350z, aftermarket, altima, amp, bose, converter, coupe, g35, line, mtx, output, radio, req, sedan, speakers, stock, system
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
