My SPC A-Arm installation
#167
Also, and this might sound stupid, I may just be over thinking it….. The camber arms are labeled L and R. AKA Left and Right. Now, Is this from the perspective of staring at the car, or is it like most things when I'm sitting in the drivers seat. AKA the L is for the Drivers side and the R is for the Passengers side. Please any help is great.
#170
Sorry the bolts that connect the a arm to the body. I have coilovers, so the spring compresser won't go into the spring. The slot is to small. Do I have loosen the spring all the way aka raise the coilovers as tall as it can go? Or should I just drop the strut. The instructions say to use a spring compresser to get the bolts out of the a arm...
#172
#174
Bumping an old thread here, but I've gotten way too intimate with my front and rear suspension components in the last week. This isn't even a love-hate relationship. I've used a myriad of tools including, but not limited to a sawzall, torch, mallet, hammer, punch, press, and breaker bar.
Over the course of several days, I've installed BC Type BR coilovers and a SPC rear toe / camber kit on my 2006 G35X sedan. The last on my list to install is the SPC front camber kit with the upper control arms. As with any 9 year old car that grew up in the Rust Belt, it seems like every bolt and nut has wanted to latch on to its neighboring metal and hold on for dear life.
My question is... has anyone else had difficult with the nut on the upper control arm? This is the nut held on with a cotter pin. For me, the cotter pin broke and even after trying to grind off the affected area, the nut remains.
http://s71.photobucket.com/user/shaw..._5771.jpg.html
Can I cut off the original control arm and drill out the bolt? I'm not planning to go back to the OEM control arm...
Thanks in advance!
Thanks in advance!
#175
Thanks in advance!
Thanks in advance!
When I did mine I don't remember having trouble with the ball joint but one of the pivot bolts broke off on one side-luckily I was able to free the remaining stud I think it had enough exposed to grab with vise grips or I could have been in real trouble trying to get it out.
