Rotor Rust, Can I use White Ox? Pics inside
Old Sep 12, 2009 | 02:43 PM
cpufreak3's Avatar
So I've got rotor rust which is pissing me off. I know it's normal, but I'm looking at my 08 Maxima parked right next to my G with no rust at all.
Also, I don't think my OEM rotors had this much rust on the hat (I think it's called?).
Now I want to know if something like White Ox will work?
http://www.veoh.com/browse/videos/category/educational/watch/v6531694X7DtSa7Z
Old Sep 13, 2009 | 05:05 PM
in2win's Avatar
nothing is going to permanently remove the rust, rust is exposed metal to the elements. you need to remove the wheels, light sand off the rust, primer and spray paint the rotors with high heat BBQ paint. thats a somewhat long term fix and will last most likely for the life of the rotors.
Old Sep 13, 2009 | 05:09 PM
PTownG's Avatar
those rotors look exactly like the ones I got here:
http://www.z1motorsports.com/350_g35...oducts_id=2212
except for the rust
They came zinc coated and so far they look shiney new after a year
Old Sep 13, 2009 | 06:23 PM
cpufreak3's Avatar
Hmm.. yeah, these aren't zinc-plated and it didn't even cross my mind till they were mounted.
I paid $180 for all four rotors and pads, shipped. In terms of rust, I got what I paid for...
except for the rust
Old Sep 15, 2009 | 12:19 AM
in2win's Avatar
$180 for PADS and ROTORS, SHIPPED....you should have expected rust. paint em for $8 bucks...
Old Sep 15, 2009 | 12:32 AM
WhosRich's Avatar
180 for rotors AND pads?! for that price, i dont think i could complain about rust.
Old Sep 15, 2009 | 12:36 AM
Dubi2087's Avatar
I paid that much for just one rotor LOL
Old Sep 15, 2009 | 04:43 PM
cpufreak3's Avatar
True, I'm not complaining (as in bashing the company).
I was just expecting if they put the effort into drilling/slotting, they could've hit it with some zinc.
Guess I'll be painting this.
Also, I had these installed at a side-mechanic and they have a little squel. He's saying the pads are cheap, but they're ceramic, so I feel it's an improper install causing vibrations. Any input?
Old Sep 23, 2009 | 10:51 PM
in2win's Avatar
my Axxiss Ultimates PADS cost as much are your whole rotor and pad setup. Just because they are ceramic doesnt mean they are a quality pad, what pads are they?
Old Sep 23, 2009 | 10:55 PM
tdruk's Avatar
i have that rust too, looks like crap i hate it!
Old Sep 25, 2009 | 02:18 PM
T MoRG x's Avatar
My stock rear rotors have an extreme amount of rust after I got the pads changed and rotors machined(oem pads). I figured it was caused by the insane amount of humidity the northeast got this summer.
Am I right to assume so? ONly fix is removal, sanding and painting? I didnt think you could paint the rotors regardless if its high heat or whatever.
Old Sep 25, 2009 | 07:00 PM
cpufreak3's Avatar
The pads are Verto. I understand they're not necessarily quality, but even my cheap-*** pepboys pads in my Honda accord don't make any squeals at all.
Also, I tried the white-ox. Removed the rust... and came back 20 mins later. Good if you wanna paint it after that.
Old Sep 25, 2009 | 08:14 PM
PTownG's Avatar
You can paint them. High temp engine paint holds up fine.
Old Oct 19, 2009 | 09:38 PM
cpufreak3's Avatar
Just to update this, I took it back to my mechanic and he fixed the squealing.
The problem was that the shims melted off the pads and were vibrating.
I think the pads were at fault since the manufacturer did not properly glue/adhere the shims on.
That also explains why the squealing didn't start for a month. It must've taken about that long until the shims finally came loose.
Anyway, the shims have been removed and the pads have been backed with CRC disc brake quiet.
Loving my cheap brakes and rotors now.
Old Oct 19, 2009 | 10:42 PM
VQdriver's Avatar
Where did you get your rotors and pads from? Just curious as I will need to source brakes for other vehicles in my family's fleet. I take it those pads aren't very good at all...Spray paint works well on bare rotors! lol
