Camber Kits $ vs $$$
Hey Everyone,
I'm in the process of doing some suspension work on my 2004 Coupe (auto) (fenders rolled)
So far
Varrstoen ES1
19x9.5, 255/35/19
19x10.5, 275/35/19
What I'm contemplating on buying...
Tanabe Sustec Pro S-OC coilovers
My question is when I get the coilovers installed, I plan to have front and rear camber kits also installed. I look on Ebay and there are front camber kits priced around $100, rear camber kits priced around $100, then you have SPL or Eibach kits costing triple. Should I splurge more on the actual coilovers or besides the obvious fact of quality of materials used, should I spend the same amount on a camber kit as I will do on my coilovers?
Thanks for any help you can give me...
So far
Varrstoen ES1
19x9.5, 255/35/19
19x10.5, 275/35/19
Some camber kits are known to break and some don't adjust much with positive camber. The general consensus is that SPL and SPC (most recent version) are the top brands regarding reliability and adjustments. Naturally they are the more expensive as well. I haven't researched in many of the brands so I would suggest doing so.
What Herrschaft said. Buy SPC front and rear camber kits and be done with it.
SPC rear camber kit with toe bolts is cheap. Buy it. You will regret it if you don't.
SPC front camber kit is expensive, comparatively. If you cannot afford it, get Kinetix front camber kit, or another name brand front camber kit.
Gary
Just use common sense and look at what the sellers all about...
boostelevator
Engine - Power Adders
09-09-2015 05:56 PM
