6MT output shaft bearing/bushing replacement?
Old Feb 25, 2015 | 10:13 PM
obender66's Avatar
Hi all,
Story started with what seems a play in driveshaft yoke at transmission side. I got in touch with driveshaft manufacturer(I have 1 piece aluminum driveshaft) who suggested that at 30K km it is VERY unlikely that (heavy duty)yoke will wear out and suggested to look into output shaft bushing replacement.
I pulled some diagrams and transmission tail assembly goes(from rear) as oil ring/bushing.
That aside-can this bushing be replaced without taking transmission completely apart? As per diagram it seems that tail section can be unbolted relatively easy.
I've been plagued with driveline vibrations at 130+km/h lately and cold weather whine since day one(I have this car since 2005) and inclined to do this job.
Sad part-I looked up transmission shops in Toronto-lots of negative feedback One genius actually pointed out that I have non factory wheels which cause vibration(5 spoke sedan OEM with Infiniti center caps..right)
Any input is appreciated!
Alex
Attached Thumbnails 6MT output shaft bearing/bushing replacement?-z33_321-1.gif   6MT output shaft bearing/bushing replacement?-z33_321-2.gif
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
mann1961
Aug 9, 2015 08:44 AM
KevinnnVo
Jul 28, 2015 06:29 PM
