Help.
Old Mar 12, 2008 | 09:37 AM
MixturePinoy's Avatar
Question Help.
This morning I went to warm up the car. Upon start up all lights on the dash seemed fine. Then when I began to drive it a few lights went on, brake, slip, vdc off, and [!]tps. I ran it for about half a mile until i pulled over and turned the car of for a minute. I turned the car back on and the lights were still there. I drove the car for a good 2 miles or so with those lights still lit up. There's no CEL light lit up, just those 4 lights. I have an 04 5AT coupe w/ almost 82k. Anyone have an idea why this happend? Thanks
-tito
Old Mar 12, 2008 | 09:42 AM
nickraine78's Avatar
God punishing you for your thread about banging your twin?
Is all seriousness any mods?
Old Mar 12, 2008 | 09:44 AM
Old school welded upper plenum, short ram intake, ypipe, custom muffler delete...
I'm wondering if i have to change my rear diff fluid..
Old Mar 12, 2008 | 09:45 AM
GreenGoblin's Avatar
The goblin resurrection
That is strange that there is not cel with all that. I would try to reset it and see what happens
Old Mar 12, 2008 | 09:46 AM
MY mitsu did a similar thing and it was a loose battery ground. Grand Cherokee did something like this too, check engine and another light cause the gas cap wasn't on all the way.
Old Mar 12, 2008 | 09:47 AM
Yea' i found it strange that the CEL didnt go off as well..
Old Mar 12, 2008 | 11:06 AM
ttt
Old Mar 12, 2008 | 11:56 AM
Jeff92se's Avatar
Red Card Crew
Check your brake fluid level. Or you pads could be worn out, lowering the brake level in your master cylinder
Old Mar 12, 2008 | 12:07 PM
I changed my front pads not too long ago, you think it may be sensing the rears?
Old Mar 12, 2008 | 12:12 PM
Mo's Tre' 5's Avatar
wow i have a whole thread that i just started about 2 weeks ago with the same problem...i was askin everyone what the problem is ...i got the same answers ..brakepads, fluid, and just reset everything...nothing worked...my lights are still on!!...lol....i have to go to Cerritos Infiniti to find out what the problem is ...their bitch a$$e$ are going to charge my $117.00 just to hook it up to do a diagnostic...u believe that!......well i gotta do it ..i tried everyone elses suggestions (thanks to everyone that commented on my thread)...
here u go Mixturepinoy if u wanna take a look at the thread..the only light i didnt have on that u did was the tsp!....
https://g35driver.com/forums/showthr...o%27s+tre%27+5
Old Mar 12, 2008 | 12:14 PM
Thanks Mo'.. how many miles do you have on your G?
Old Mar 12, 2008 | 12:35 PM
its almost at 53,000....thats it!...lol......i changed out my front brakes just like a week ago...and got my front rotors resurfaced...none of those worked...i asked the mechanic who resurfaced my rotors if i needed to get my backs one done....he looked at it and said i have a good 6-7 months left on my back brakepads and when i change out those resurface the backs too!....he only charged me $50 to resurface my rotors...everyone else charged $180-$200....b1tches!!!....lol...........
Old Mar 12, 2008 | 12:38 PM
I'm thinking it's the fluid or its sensing the rears.. the brake light only turns on when the hand brake is pressed, and i think that's located in the rears? the VDC is also in the rear.. so i'm assuming it's the rear that's causing these lights to light up. I also changed out my brake pads not too long ago. but it was only the fronts, just like you did..
Old Mar 12, 2008 | 12:54 PM
yea ur probably right..ima' probably take it into infiniti today..if i can!...
Old Mar 12, 2008 | 02:29 PM
Jeff92se's Avatar
Red Card Crew
Brake fluid level?
