Vortech Inline Fuel Pump alternative
Old Aug 15, 2008 | 07:27 AM
civic4982's Avatar
so I'm still needing a vortech inline fuel pump to complete my makeshift "full kit" on my revup g35.
thus far I've got the unichip with the preloaded map and am working on getting things finalized on a vortech FMU. both of these are to go along with my tuner kit that I bought new.
now if I have trouble finding a used vortech inline fuel pump is it reasonable to replace it with an in-tank fuel pump instead?
or, if I get, for example, a walbro 255 LPH pump that most people use will I have to step it up to get new injectors? I keep hearing that if I get a walbro 255 LPH pump that it will increase strain on the injectors and I won't be able to get by without new ones.
I also have no idea if the vortech FMU is related to the inline fuel pump so I wanted to see if a different pump could be combined with that FMU and still be compatible.
I'm trying to temporarily avoid the cost of new injectors and simply run a out of the box vortech full kit.
thanks.
Old Aug 15, 2008 | 02:52 PM
zazaracing's Avatar
Team Transport Member
It should just be the amount of fuel coming in... the inline plus your stock should be the same at the walbro alone. I really would change injectors if you dont want to be running your injectors at a HIGH output but thats just me
Old Aug 15, 2008 | 04:17 PM
civic4982's Avatar
I just learned recently that I cannot use the Vortech FMU if I plan on usinga walbro 255.
This is because the FMU is connected to the inline fuel pump to regulate it. Also the Vortech FMU for the revup is 10:1 with no spring as opposed to the non-revup being 7:1 with a spring loaded style
Old Nov 22, 2008 | 02:01 AM
crashnburn's Avatar
also a utec will not control the inline pump either... i just ran into that problem with my install... i went with a walbro 255, i already had 440cc injectors
Old Nov 27, 2008 | 12:28 AM
civic4982's Avatar
GTM has controlled the inline pump with a UTEC already. they utilized an on/off solenoid function that is normally used for things such as methanol and nitrous to control it.
Old Nov 27, 2008 | 12:44 AM
Po12no's Avatar
haha i was just going to ask the same thing you did ... how are is the fuel pump to change?
Old Nov 27, 2008 | 12:54 AM
crashnburn's Avatar
i have a inline pump that i didnt use.. i used a walbro
Old Nov 27, 2008 | 01:17 PM
Po12no's Avatar
where is the best place to the the walbro at?
Old Nov 27, 2008 | 03:17 PM
str8dum1's Avatar
they are the same price anywhere. just get it here http://www.intensepower.com/wa25hiflfupu.html
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
