350Z VQ35DE Engine Build
Old Feb 24, 2012 | 07:08 AM
Robert_K's Avatar
Figured I'd help PowerFab out and share (*****) my engine build they are doing for me. Little background for those that don't know... Oct '05 traded in my '03 Evo 8 for my current '03 350Z Touring 6sp. April '08 added the JWT 700BB (GT28RS) Twin Turbo kit among other mods. About a year after that regretted not building the block and talked about doing it for years! 31-Dec-11 It was loaded up and towed to PowerFab where an Import Parts Pro Stage 3 long block and other mods is being installed. Should net around 550-575whp+ on pump. See below...
Current Set-up:
Vehicle: 2003 Nissan 350Z Touring 6sp
Engine Code: VQ35DE
ECU: TurboXS UTEC
Audio & Electronics:
- Bel RX65 Laser/Radar Detector
- Boyo VTL300 Rear Camera
- Clifford Matrix 12.5 Security Alarm
- Defi-Link 60mm BF Series Boost Gauge & Fuel Pressure Gauge
- Defi-Link Control Unit, Display & Indicator II
- JL Audio 500/5 Amp
- JL Audio 10W3v3 Sub
- JL Audio C5-650 Components
- JL Audio TR650Cxi Rear Speakers
- Nismo Horns
- Optima Yellow Top
- Pioneer AVIC-D3X DVD/Nav Receiver w/ XM SAT Nav
- TurboXS DTEC Map & Tuner Wideband
- TurboXS UTEC w/ Map Switch
- Wicked CAS 350Z Corner Box
Brakes & Suspension:
- Aerosync CF Strut Tower Brace
- GTSpec Fender Braces, Front Tie Brace, Rear Lateral Arm & Rear Tie Brace
- Hotchkis Stage 1 TVS Kit
- PFC1038 Front Pads
- Posi Quiet Rear Pads
- SPL Endlinks (F&R)
- StopTech Big Brake Kit (14" 4-Pot Front, 13" 2-Pot Rear)
Engine & Drivetrain:
- AP Stainless Steel Clutch Line
- ARC Oil & Raditor Cap
- ARC V2 Oil Catch Can
- AutoTechnic CF Shroud
- Gallery Belmount Blue Dress Up Kit
- JWT Clutch & Flywheel
- JWT Oil Pan Spacer
- NGK Iridium IX 1-Step Colder Spark Plugs
- Project Kics Magnetic Oil Plug
- RC 750cc Injectors
- Stillen CF Battery & Brake Fluid Covers
- Stillen CF Engine Cover
- Stillen Oil Cooler
- UR Underdrive Crank Pulley
- Walbro 255lph Fuel Pump
Forced Induction:
- HKS SSQV BOV
- JWT 700BB Twin Turbo System
- Perrin Boost Solenoid
- Swaintech BBE Coated FMIC
Intake & Exhaust:
- APS 2.5" Test Pipes
- Cosworth Intake Plenum (Polished)
- Stillen True-Dual Cat-Back Exhaust
Interior & Exterior:
- Aerosync N-Style Front Bumper
- AUT Carbon Fiber Z Emblem Filler
- CraftSquare TC-N1 Mirrors
- Dual Guage Pod A-Pillar
- JDM Fairlady Z Emblem & Smoked Markers
- Nismo Sides
- Nismo Ti Shift ****
- '06 OEM LED Taillights
- Perrin Shorty Antenna
- Rear Strut Brace Carbon Fiber Cover
- Removed Rear Wiper
- Seibon TS-Style Carbon Fiber Hood
- Seibon TT-Style Carbon Fiber Rear Lip (Custom Painted)
- Shift Style Custom Shift Boot
- TEIN Hood Damper
- 15% Tint
- TiTek Dry CF Air Duct
- Varis CF B-Pillars
Wheels & Tires:
- ARP Wheel Studs (15mm longer)
- Ichiba Wheel Spacers (5mm Front)
- Project Kics NeoChrome R40 Racing Lugs w/ Locks
- Work Meister S1 3-Peice (19x9.5 & 19x11)
- BF Goodrich KDW Tires (255/35-19 & 285/35-19)
Last Dyno:
2012 Build:
IPP Custom Stage 3 Long Block:
~~ Cosworth Rods, CP 8.5:1 Pistons w/ Ceramic/Moly coating on the piston tops & skirts
~~ ACL Trust Washers, Main & Rod Bearings
~~ ARP Main Studs & Rod Bolts, L19 Head Studs
~~ ATI Street Damper Crank Pulley
~~ Heads Redecked, Ported Intake/Exhaust Runners, 5-Angle Radius Cut Valve Job
~~ JWT C2 {261* w/ .456 (11.58mm) lift Intake & Exhaust} Cams
~~ JWT Heavy Duty Springs & Shims
~~ Viton Valve Seals
~~ OEM Gasket kit with Cometic Head gaskets
~~ OEM VQ35 "Rev-Up" Oil Pump
~~ OEM VQ35 Pathfinder Rear Cooling By-Pass
~~ Nismo Low Temp Thermostat
~~ Z Speed Performance Aluminum Undershroud
Fuel:
~CJM Stage 2 Return Fuel System w/ Blue Billet Fuel Rails
~~ Aeromotive 340lph In-Tank Fuel Pump
~~ Injector Dynamics 1000cc Injectors
EMS:
~ HalTech Plug-In Pro ECU Replacement EMS
~~ HalTech Boost Control Solenoid
~~ HalTech Dual Wideband Kit w/ 2 Sensors
~~ Dual Wideband Gauge
Drivetrain:
~ Nissan CD009 (2004+) 6sp Transmission
~~ Carbonetic Twin Disc Carbon Clutch w/ Carbon/Steel Flywheel
~~ Quaife Helical LSD
~~ SPL Solid Diff Bushings
Exhaust:
~ Greddy RS Cat-Back Exhaust
~ PowerFab 3" PolyDyn Coated Downpipes
~ PolyDyn Coated Manifolds & Turbine Housings
Suspension:
~ KW Variant 3 Coilovers
~ SPL Front Upper Arms
~ SPL Rear Camber Links
~ SPL Eccentric Lockout Kit
Wheels & Tires:
~ HRE P43SC in Satin Black
~~ 19x9.5 +20 & 19x11 +25
~ Toyo R888 (Still Researching)
~~ 265/30-19 & 305/30-19
Pics:
Old Feb 24, 2012 | 07:41 AM
Phillip_G35's Avatar
Thats a nice Z!!! Great to see some 350z around here! lol
Old Feb 24, 2012 | 08:34 AM
SDGenius's Avatar
sweet Z
Old Feb 24, 2012 | 10:32 AM
Sylvan lake V35's Avatar
Nice can't wait to see the results. Does MeatBag work at Powerfab?
Old Feb 24, 2012 | 10:44 AM
Robert_K's Avatar
Thanks! And yes... MeatBag does work/own PowerFab.
Old Feb 24, 2012 | 10:51 AM
lsmooth81's Avatar
Nice
Old Feb 24, 2012 | 11:07 AM
Frankieg35's Avatar
That's why his car is such a beast!! Haha Nice build!!
Old Feb 24, 2012 | 12:37 PM
I would like to see what the 700bb kit maxes out at, are you running meth/water injection? I was planning on maxing out the 850bb kit but I have changed my plans a little looks like you have a pretty solid build
Old Feb 24, 2012 | 12:39 PM
Robert_K's Avatar
We're thinking 550-575+ on 93 pump. I've considered water/meth but not at this time. Thanks!!!
Old Feb 24, 2012 | 12:48 PM
I bet water/meth would help you hit the 600whp mark, I have heard the JWT intercoolers lose efficency at anything over 500whp. I have had mine to over 600whp I was using water/meth. For my retune I should try without water/meth and see what the difference is, if the JWT are being maxed out it might provide a greater benifit . 550-575whp would be enough to put a smile on your face daily.
Old Feb 25, 2012 | 02:35 AM
Robert_K's Avatar
Will see what this month's bill is and if I want to add it or not. I have some other plans before meth. It mostly likely would take me over the 600 mark though. And it is a benefit with Houston's summers.
Old Feb 25, 2012 | 09:25 AM
GreenGoblin's Avatar
The goblin resurrection
Looking good Robert, can't wait for updates.
Old Feb 27, 2012 | 01:28 PM
Robert_K's Avatar
Well talked to PowerFab today. Kinda just getting a weekly status update and not much has changed. Engine is still at G&G, HalTech is still saying sometime in March, no update on the Teins and hopefully will have a word back on the intercooler and piping this week.
On a personal note... Iraq is still not issuing entry Visas. So until they start I can't leave without quitting my job. Have 40 days till my R&R so wife & I are hopping for some good news soon. But I did get promoted this month and pay day is this Friday. And payday is looking good with the pay increase.
Old Mar 7, 2012 | 11:00 AM
Robert_K's Avatar
So an update on my build....
First I ordered '06+ Bi-Xenon headlights from 350ZSource and they don't stock them, they drop ship with no ETA. Cancel that order and found them at Courtesy Nissan. They are being shipped directly to LightWerkz for painting and other upgrades.
Went ahead and order the tires from TireDirect.com; Toyo R888 265/30/19 & 305/30/19. Being shipped to EVS Motors so they can be mounted/balanced on their new Hunter Road Force GSP9700 Balancer.
Spoke with PowerFab and still waiting on the engine to get back from G&G and IPP. The Tein coil overs should be deleivering soon and, of course, still waiting on the HalTech Plug-In Pro. Lastly, PowerFab saw a timing chain failure so we're going to replace that while we have the engine out & opened.
Everything is falling into place slowly. Now if I can just have the Iraq Gov't grant us Visas so I can get home everything would be perfect!!!
Old Mar 7, 2012 | 06:57 PM
superchargedg's Avatar
Rob you are officially a ***** now for coming on this site...........too........lol
