04 G35 coupe Driver headlight issue
Hey guys,
Recently my driver's side headlight went out. I had this same problem back in June of 2014, found out it was a ballast issue so I ordered a new ballast, and it worked fine. Fast forward to last week, the headlight went out again. I took off the headlight, and checked three different bulbs to make sure it wasn't the bulb that went out, but none of them worked in the ballast.
So I ordered a new ballast, less than a year of purchasing the previous one, and waited for it to arrive. This morning it came in, and I got to work. I placed the new ballast in, and no light. Again I tried three different bulbs, same thing, no light. Then i thought maybe it was the igniter, so I tried a different one, and tried all three bulbs again, still no light. So then I removed the battery and checked the fuses, and all the headlamp fuses are fine.
My question is, what else could it be? Could it be that I just got a defective ballast? Should I order a new igniter?
Also, what could be the reasoning that the ballast can go bad in such a short amount of time? I know that is a pretty vague question, but I can't seem to figure the issue out. Thanks in advance!
Cheers,
Cheers,
I'm assuming you got the "new" ballast used? These are easily the most common problem, and you're right to check the ballast first. Easiest way to tell is to switch the pieces, one at a time, from your working headlight to your bad light until it works and you find the problem.
