G35 AUTO transmission problem??
Old 08-16-2008, 03:06 PM
ckg35's Avatar
From what I've read, there are more issues reported with the 6MT than the automatics.
  #32
Old 08-17-2008, 12:53 AM
digitalgulby's Avatar
I sometimes will get a little driveline stutter, but the trans seems to hold up pretty good. Like I said earlier, I intended to buy a 6MT but the 5AT felt much more solid.
  #33
Old 08-17-2008, 02:26 AM
OCG35's Avatar
Normally I wouldn’t post in a thread like this because for the most part I have no problems...
However - I feel a certain level of responsibility to mention the one major issue I have with my 04.5 AT...
MTs are surprised when I kick their @ss'... its a bit frustrating - but like most things in life, you learn to live with it.
Happy AT moding
  #34
Old 08-22-2008, 01:21 AM
OG 35's Avatar
i have the same exact car you want.. 03 black on black and i have no
problems what so ever.. 74k on it .. mainly highway miles.
  #35
Old 08-22-2008, 04:50 PM
llut5at's Avatar
I was just wondering, I've got a 5AT, but I usually use the triptronic, even for everyday use. Is that bad for my transmission or should it be alright?
  #36
Old 08-22-2008, 05:04 PM
Drewer's Avatar
Originally Posted by joedaddy1
IIRC.. the tranny was used in the Q45.. so our trannies are designed for more hp/tq than our engines can provide, hence the great reliability (at least, longetivity :eeps
True. The same JATCO5 is used in the cars with the VK45 (M45 for sure, but I don't remember if there was a Q in 2003 model year?). Since those engines are rated at 333 ft-lbs, it's safe to say that our cars won't reach the safety threshold without modifications.
I've used the manu-matic almost exclusively for over 100,000 miles, and I've had 0 problems with the trans in either drive or manu-matic. (Or whatever infiniti calls the manual shift mode.) At 114k now, and still going strong.
  #37
Old 08-22-2008, 05:06 PM
llut5at's Avatar
thanks ^^
  #38
Old 09-16-2008, 06:07 PM
JBALLA's Avatar
96k on mine and no problems!!
  #39
Old 09-17-2008, 10:29 PM
05 sedan's Avatar
well i have 33k and mine just went out its going to be replaced. why? had my car serviced at Glendale Infiniti and they were supposed to change the trans oil. they removed the oil but forgot to put some back in . I drove to las vegas on 1 quart.
  #40
Old 09-17-2008, 11:03 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
44kmi, no problems what so ever with the car/transmission. Fluid changes done on schedule, and I use manumatic 25% of the time.
  #41
Old 09-18-2008, 01:25 AM
jack_burton's Avatar
the nissan 5 speed auto is pretty close to bulletproof...
  #42
Old 09-18-2008, 06:23 AM
OCG35's Avatar
No matter who changes your oil - ever if its' YOURSELF... check the level after a few dozen miles/day or two...
always.
*Edit/// this is for any fluid/oil.. motor, trans, rad, power steering, brake, dif (after svc)... even windshield washer fluid... Check your fluid levels!
  #43
Old 09-21-2008, 04:29 AM
edwpor's Avatar
i have a coupe 80 k
am having problems with my tiptronic it lock in N for hours and then it un locks dont know the problem !!
  #44
Old 09-25-2008, 10:30 AM
meiso's Avatar
Originally Posted by Hotdawwgman
^Really? Thats really good to know... But has anybody driven there car on long trips to get a lot of heat soak inside the car???? Every time i drvie a good distance it gets really warm in the car.... Its gets really hot on canyon runs!!! (sorry... didnt mean to jack the thread)
I have when I do driving from OC to LA county, like Valencia it gets really warm in the car. My wife feels the heat by her feet like if I have the vents turned on for the floor, I barely run the fan in the car and she feels it.
  #45
Old 09-30-2008, 10:44 AM
Blakerson's Avatar
I have an 03 5AT with 64k and have not had any issues.
Quick Reply: G35 AUTO transmission problem??
