G35 Sedan Suspension Picture Compilation Thread
Rating: Thread Rating: 4 votes, 4.75 average.
  #796
Old 08-15-2011, 07:25 AM
NFSP G35's Avatar
? = 2B || !2B
WARNING! Sedan Drivers Present!
Extreme danger of trolling, shenanigans, PWNING, lulz, and just general internet silliness
Proceed at your own risk
The following 2 users liked this post by NFSP G35:
JaE35 (08-23-2011), jookyshank (08-15-2011)
  #797
Old 08-15-2011, 12:20 PM
alpa_chino's Avatar
^lol...awesome!!
  #798
Old 08-15-2011, 12:25 PM
jookyshank's Avatar
I haz hugz to givez
Ash FTW! lmao
  #799
Old 08-16-2011, 08:43 PM
EMSLIFESAVER's Avatar
Angry Loud snapping noise from my front driver's side
I have a 2004 G35x sedan and I have a loud metal snapping noise coming from my driver's side front end. The sound is present at all times and nothing makes it better or worse. It has gotten progressively worse over the last couple of months. My rotors and pads have been changed and my compression rod and cv axle joint assembly has been repaced but the sound is still present and unchanged!!!! I took it to the dealer but they said it was the cv axle assembly which I have replaced. My car has 60K miles on it. Please help!! The noise almost sounds like someone throwing a fork it a garbage disposal as it is being shut off??? I have checked the wheel for movement when it was off the gorund and it seems tight, in fact, everything seems tight!!!
  #800
Old 08-23-2011, 09:47 PM
bmwdinamo's Avatar
Question:
I have an 03 sedan and i just installed 04 coupe suspension ( shocks, springs, control arms, etc)
I can feel a lot less body roll than stock but now my ride is really bouncy. I can feel every little bump in the road. Is that normal?
My rims are stock with stock tires.
Any input will be appreciated.
  #801
Old 08-23-2011, 10:01 PM
jookyshank's Avatar
I haz hugz to givez
Possibly your '03 set was blown?
  #802
Old 08-23-2011, 10:06 PM
bmwdinamo's Avatar
My stock set had bad strut mounts.
  #803
Old 08-24-2011, 11:14 AM
MPJ's Avatar
MPJ
MPJ is offline
03 350z tein s-tech (with 1" cut off front spring and 3/4" cut rear spring mount. Sorry about the bad pic and don't worry I removed the tein sticker. lolG35 Sedan Suspension Picture Compilation Thread-img_0206-2-.jpg
  #804
Old 08-24-2011, 11:16 AM
MPJ's Avatar
MPJ
MPJ is offline
Originally Posted by TreyJoh2
What wheels are those? And where can i buy some?
What front bumper and lip is this?
  #805
Old 08-29-2011, 12:32 AM
chinleewan916's Avatar
Will 03 350z Tein S fit 03 g35 sedan?
I herd tein s for 350z will have a extra drop on g sedans? Is that true?
  #806
Old 08-29-2011, 07:54 AM
MPJ's Avatar
MPJ
MPJ is offline
Yep. 1" extra on a sedan.
  #807
Old 08-29-2011, 02:49 PM
So if i buy tein s for 350z it would be a 3in drop front and 2.3 rear drop?? Do you think it will rub, i have stock rims n tires?
  #808
Old 08-29-2011, 02:54 PM
JaE35's Avatar
Moderator
G35 Sedan
advertised drop for z s-techs is .6"...so your looking at a 1.6 spring drop front and rear....if you use z shocks/struts you can add another .5 to the full drop front and rear
chinleewan916 (08-29-2011)
  #809
Old 08-29-2011, 03:20 PM
Im changing springs only, so its 1.6 drop all the way around using 350z s tech, that means im better off using s tech for g sedans because its advertize to do 2in front/ 1.3 rear. Any suggestions?
  #810
Old 08-29-2011, 03:26 PM
JaE35's Avatar
Moderator
G35 Sedan
i wouldn't run 350z stechs on your stock sedan shocks...you'd murder them in a few months....what you get out of the z springs are outstanding spring rates
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
Quick Reply: G35 Sedan Suspension Picture Compilation Thread
