G35 Sedan Suspension Picture Compilation Thread
Rating: Thread Rating: 4 votes, 4.75 average.
  #91
Old 07-19-2009, 02:32 PM
Wannabe6MT's Avatar
-MN G Crew-
^did you get new wheels?
  #92
Old 07-19-2009, 09:11 PM
SDGenius's Avatar
yeah, the OZ's
  #93
Old 07-19-2009, 09:36 PM
t3chnique's Avatar
Originally Posted by SDGenius
no, i have 35 series tires upfront at the moment and 40's in the rear. tires came w/the wheels. BTW, what i meant with my answer was since the 350Z springs and G sedan springs are interchangeable, any drop for the Z is that + 1" when you put those same springs on a G sedan.
yeah i read about that in the FAQ sticky made by ttrank.
thanks again tho
  #94
Old 07-22-2009, 11:21 AM
Diggs's Avatar
Anyone know where to buy springs cheap in the GTA?
  #95
Old 07-28-2009, 12:13 AM
TOYJOETA's Avatar
SDGenius, if I followed your posts right you have H&R's and Eibachs. How do the two compare? i.e. Which has the lowest drop and which has the better ride? I want to lower my wife's car but don't want it to low that I have to worry about her hitting something and still need it to have a nice ride.
Thanks allot
Joe
  #96
Old 07-28-2009, 12:47 AM
SDGenius's Avatar
ride's pretty close, really depends on what size wheel. 17's or 18's will be super smooth but the drop will be really agressive. the H&R's have more of a drop but i'm running them on 19's and my Wife's Eibach's are on 18's... so she scrape's a lot more.
19's/20's = more ground clearance but harsher ride
17's/18's = more prone to scrape but smoother ride
it's just depends what ur lookin' for, i guess...
Sheridan79 (06-14-2012)
  #97
Old 07-28-2009, 01:09 AM
Swivel's Avatar
Moderator
Watch the Canada Marketplace, they come up every so often. Keep an eye on the US, too, they are not too expensive to ship. Also try my350z for a full set of revised (04.5-up) springs and shocks/struts.
  #98
Old 07-28-2009, 03:40 AM
hawaii's Avatar
Sedan h techs
Here are my sedan h techs on stock 17's.
BEFORE:
[IMG][/IMG]
AFTER:
[IMG][/IMG]
  #99
Old 07-28-2009, 06:48 AM
PAIXAO's Avatar
Originally Posted by SwivelHips
Just another sedan on Z fronts and coupe rears
What size tires are you running?
  #100
Old 07-28-2009, 11:10 AM
TOYJOETA's Avatar
I plan on runnin 245's front and rear with coupe 18's on a sedanx. hopefully that will give me enough clearance. thanks for the input.
  #101
Old 07-28-2009, 07:10 PM
JoClezyG35's Avatar
  #102
Old 07-28-2009, 08:47 PM
monkgee's Avatar
looks nice.. i want some splash guards.. im gettin my wheels powder coated this week.. (19" rays) on my GF sedan... ill post pics when done..
  #103
Old 07-28-2009, 08:49 PM
G35Papa's Avatar
Tein CS Coilovers
~ Priced at around $1500+
~ Fully adjustable (height and dampner) - OEM style (direct replacement of spring and shock in the rear)
~ Ride quality - Comfy, "OEM like". Not "too stiff" in any way, even at the stiffest setting.
Stance GR+ Coilovers - 12k/5k spring rate
~ Priced at around $1200+
~ Fully adjustable (height and dampner) - True coilover (OEM spring and shock are replaced with a full strut in the rear). With the Stance you are able to retain the pre-load on the spring as the height adjustments are seperate from the spring pre-load collars. (hope that makes sense)
~ Ride quality - Stiff, not your moms old Buick . Definately a sporty stiff ride. Feels great around corners and you can feel the bumps in the road. Papa like
I couldn't even turn my front wheels in this shot but I like how slammed it is so I'll post it
The following 2 users liked this post by G35Papa:
a-nguyen93 (05-07-2012), Sheridan79 (06-14-2012)
  #104
Old 07-29-2009, 08:50 AM
OCG35's Avatar
what color is your car and where do you live? I have a set of DG mud guards (if you are local).
  #105
Old 07-29-2009, 10:31 AM
Swivel's Avatar
Moderator
In this pic I'm running stock coupe size: 245/40 rear and 225/40 front. I've since switched to 235/35 front which I'm not happy with; they look too small. But I couldn't resist a pair of T1Rs for $200! I didn't like the 225s either since they looked a little stretched and I prefer a straighter sidewall. Eventually I'll go with 245/35s all the way around, but probably not until at least next spring.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
Quick Reply: G35 Sedan Suspension Picture Compilation Thread
