Fuel gauge problem. Detailed.
Old 07-18-2015, 04:33 PM
Max626's Avatar
Originally Posted by ranhood
So it seems that a repair or replacement of the cluster is the solution. A google search shows a few places repair for $125 - $180. If you tested both sender units - and performed the test SkylineSedan took time to show/link... cluster fix seems to be cost effective solution. I had it done on a Yukon I own about 3 years ago. Complete cure of my gauge probs. Keep us posted on things.
Link to company that does the repairs please
jk319 (07-22-2022)
  #47
Old 07-18-2015, 06:26 PM
ranhood's Avatar
Sure... www.google.com
cenzo6mt (09-27-2016)
  #48
Old 07-21-2015, 01:43 AM
TurTLe*'s Avatar
TurTLe... you still have same prob? I've just been dealing with it but sure would smile more if fuel gauge worked correctly. Can the instrument cluster be pulled as a whole and repaired? Tks for your feedback!! -r
Sorry i dont go on here as much anymore. The G is just a daily driver now that i got it where i want it to be.
But yes i still have the problem. Im 99% sure is the cluster. Been waiting to buy one that fits my exact car, AT with NAVI and cluster near 96k. Repair should fix it as well. The cluster can be pulled out and repaired. Keep in mind that car will run but not for long w/o cluster so it will need to be sitting.
This is another reason why i cant get the work done. I need my car to be up and running at any given time.
To the guy asking about dimming, there are companys that address that as well, not sure if the same guy that does the fuel gauge can do that work.
  #49
Old 07-21-2015, 02:54 PM
BuzzLightYear's Avatar
Theres was a few that popped up on Ebay the other day from around $100-200. If you read their descriptions they state what issues they fix. Heres a link to one for 199.99 that guarantees the fix of:
Intermittent or failed fuel level gauge
Intermittent gauges
Intermittent back-lighting
http://www.ebay.com/itm/05-06-07-08-...d559aa&vxp=mtr
Then theres this one for about $108 that only mentions speedometer and fuel gauge issues. You could message and find out if they also can fix the dimming issue.
http://www.ebay.com/itm/INFINITI-G35...a88935&vxp=mtr.
The following 2 users liked this post by BuzzLightYear:
jk319 (07-22-2022), Max626 (07-21-2015)
  #50
Old 07-21-2015, 07:59 PM
Max626's Avatar
Thanks I appreciate the links, i contacted the last one you posted since he's closer to me so ill let you guys know how everything goes.
  #51
Old 08-05-2015, 12:55 PM
2007G35xDriver's Avatar
I have a 2007 G35X with 129k on it.. I am having a issue with the gas mileage. when I first got the" G " and i filled up the tank i would see the display show 399 of 420 mile in the tank . I have noticed that has become 270 or so on a full tank what can i do to fix this... ? how do i test to see what is the issue? is there a sensor issue or do i just need to clean the tank? What do i do?
  #52
Old 08-20-2015, 05:11 AM
ara777's Avatar
Going through the same ordeal and I was quoted $1200 too to replace my cluster by the dealership. Way too much!!! I was thinking of using a company like 'module master' to get this rebuilt. Do you guys know if a rebuild preserves the key codes and mileage, or if there is any legal stuff I need to take care of?
  #53
Old 08-20-2015, 03:29 PM
ciraleon's Avatar
Dang, I swear, I wish there was a definitive answer on this issue. Can anyone confirm that replacing the cluster works?
I've been going by mileage for the last 2 years. HAHA
  #54
Old 09-13-2015, 11:01 AM
ara777's Avatar
ha ha! I am turning in to a mileage-based-fuel-filling-guru too! I am planning to get the cluster rebuilt next month. Will let you know how it goes.
  #55
Old 09-15-2015, 10:23 AM
tiguy99's Avatar
Appreciate this thread
  #56
Old 09-18-2015, 08:06 AM
Pedabeast's Avatar
Originally Posted by 1SlowSedan
Experiencing the same damn thing. Good old Infiniti's right??
Please this is a problem
  #57
Old 09-26-2015, 09:25 PM
tiguy99's Avatar
Have the same problem. Was told I have a bad right fuel sender unit.
Did you guys replace both units and still have the same problem
  #58
Old 09-26-2015, 11:17 PM
ara777's Avatar
In my case yes. Replacing both units didn't fix it. When I ran the self diagnosis on the cluster, the fuel gauge didn't move the expected way. So now I am sure it is the cluster.
  #59
Old 09-28-2015, 12:50 PM
05_SkylineSedan's Avatar
In my case replacing both tank senders did fix the problem in our '05 and '06 G35s. Fuel gauges operated correctly until we traded them in (for 37s) in '13.
  #60
Old 10-02-2015, 11:08 PM
TurTLe*'s Avatar
if anyone is interested in trying.
I have BOTH brand new OEM sensors for sale, it was installed for my testing purposes and used for about a week. Then i pulled it to do other stuff.
I gotta make a FS posting one of these days.
It might fix your problem, it might not.
Quick Reply: Fuel gauge problem. Detailed.
