New here.. Thinking about buying an 08 G35 with 77k miles.. Tomorrow. Advice?
SORRY TO OP FOR asking this thread, if anyone feels like I am disrespecting the OP, tell me and I'll make my own thread. Just figured since we are both looking to buy, it's okay.
Anyways, If I am buying the car from a dealership, is it a bad or smart idea to bring up the oil pressure. Say for example, they know about the car having the bad gaskets, and I bring it up. Would they check the oil pressure for me on the spot and if its low, can the car price be talked down? I'm just confused on how to treat this as most HRs will get it eventually (from what I read since they are all made of paper) and since there was no recall on it. I'm still reading the other thread.
At this point when buying used as the codes will EVENTUALLY come, meaning it will happen, do I still look at lower milage Gs (50-80k) for the 14-17g price range and pay the 2Gs when it happens or look for a higher milagr (85-100k) but cheaper g (12-14gs) and get the gaskets replaces immediately. This would be my DD so I want to make sure what I'm getting myself into. I still wanna do mods to it too but nothing major.
Thanks. I just think these cars are too nice to give up because of a gasket but 2gs is hard for me to get in my situation atm.
So in other words, buy a g35 at whatever I can afford and I think is nice. Than immediately buy a oil pressure gauge and when I see it going downhill, get it checked out. And if I don't see it go downhill, ride it till it happens or im just apart of the lucky ones. Correct ?
More like, don't even buy a car that doesn't pass an OP test in the first place. Then YES, after you own one that did pass an OP test, just monitor your oil pressure from then on.
And for the OP, does it stay low consistently even if the car has not been running? For example, what if the seller put it new oil Everytime he meets a buyer so just in case he has to do a OP test, it passes (not sure how the OP is EXACTLY Checked, but yeah). In other words, is there any way the seller can hide the actual OP readings for say the first day than after its back to the regular low readings?
Btw, thanks for the info. It has helped me out a lot. Just reading that thread gave me a great idea about the codes. Aha on page 14 currently
Your new best friend
Makes sense. Do people usually perform the OP test themselves with a device they bought or just meet at a local mechanic shop to pay them just to do a quick OP test.
As far as protecting yourself from a seller that is deliberately trying to make the OP seem artificially high by using heavy weight oil or additives, IDK, that's almost bordering on paranoia at that point, but I guess you could also pay for an oil change and supply oil of the correct spec. I'm pretty sure you'd be pissing off your seller at that point though.
If you do have an OP test done, just make sure whoever does it follows the factory guidelines for testing OP. Again, keep reading, that is all covered in those threads I posted earlier.
Testing the OP, or replacing an oil gallery gasket?
I guess it doesn't really matter though, I don't know of one for either, but then again, I've never looked. You can, however, look directly at the factory service manual and see what's involved.
http://www.nicoclub.com/FSM/G35/Sedan/2008/
Which process?
I want this car to be able to run for at least 3 years. It will be my college transportation car. That is why I am only doing small simple mods and not gonig all out and wasting my money on a turbo -_- but... yeah. If this is going to be the one of the biggest problems that occurs beacuse of OEM parts or bad maintence, than I might still buy it and replace it at a mom and dad pop hopefully for $1000-1200 in labor
#30
