04 G35 stuck in park
Old 10-09-2010, 11:25 PM
2004G35Indy's Avatar
04 Infinity G35 stuck in park. Also the brake lights seem to have gone out at the same time. Will a blown brake light fuse cause the car to stick in park? Anyone have a solution? Thanks!
Old 10-12-2010, 11:53 PM
skyline250GT's Avatar
I had a similar problem on my car, turned out to be the brake switch above the brake pedal. Replaced it everything started working again.
Brake light fuse would just affect the brake lights only, not the locking mechanism on the shifter.
Old 10-13-2010, 08:01 AM
Thanks Skyline, it was the fuse for anti-skid system. Apparently, there are four fuses that have some control over the braking system and if any one of the four goes out, it will lock the shifter. The brake switch, as you mentioned, will also lockup the shifter if it needs to be replaced.
Old 05-24-2014, 11:47 AM
Kennypowers's Avatar
Thanks!
Old 05-24-2014, 11:48 AM
just getting the hang of this thing, the exact same thing happened to me did you tell me which fuse is they are and where they are located? Thanks!
Old 05-25-2014, 12:04 PM
05_SkylineSedan's Avatar
Depends on the year and model of your car. Luckily the good folks at nicoclub have posted many factory service manuals right here:
http://www.nicoclub.com/infiniti-service-manuals
Find your model-year, grab some manuals, read up, and you can become an expert on your own vehicle.
Old 05-25-2014, 12:07 PM
I learned from another thread... it turned out to be a 10 amp fuse everything running perfectly now!
arora_g35
06-24-2020 01:58 PM
vmcarbuyer
10-12-2019 12:42 PM
netcbc
Exterior - Body Parts CDN
08-21-2015 09:50 AM
laksjd84
07-24-2015 05:12 PM
justgotg35
07-19-2015 12:33 PM
Quick Reply: 04 G35 stuck in park
