HR Y-pipe on 06 g35 coupe
Old Jan 5, 2011 | 02:35 AM
cHink's Avatar
Hey guys im thinking to get a y-pipe
i heard alot of people switch to HR y-pipe or atleast some of u.
I want to know if this is a direct bolt on for my 06 G coupe and
will this make any louder VQ tone?
Old Jan 5, 2011 | 02:37 AM
sillyoldtayo's Avatar
See here
https://g35driver.com/forums/intake-...-2003-g35.html
lots of people have done it. i actually was thinkn about doin this as of about 2 days ago haha get a little power, sound probably wont change much. Also theres different aftermarket brands you can go with out there. Just Search
Old Jan 5, 2011 | 02:50 AM
DrewLe's Avatar
The exhaust note will be slightly higher, at least from my experience. That was also with the stock sedan exhaust. Sounds even s3xier now with the coupe mid pipe that I installed.
You'll also get a slight power increase, but nothing earth shattering lol.
And pretty sure it should just bolt up to your existing exhaust.
Old Jan 5, 2011 | 04:34 AM
Footballmania32's Avatar
I love what the HR Y pipe has done to my exhaust note. Take a listen for yourself!
Old Jan 5, 2011 | 11:10 AM
gary c's Avatar
Pain simple truth you might understand!
If you want to change the sound of your exhaust and gain HP just replacing the y-pipe is not the answer. The restriction within your exhaust is the OE cats! If you replace them with HFCs (high flow cats) like BERKS you'll not only change the exhaust note but gain 10 RWHP. Replacing the y-pipe in comparison is a joke along with a waste of your hard earned $$!
Gary
Old Jan 12, 2011 | 02:49 PM
irishsig's Avatar
^agreed.
When I changed to the hr y pipe there wasn't much of an exhaust note change (nor power)
BUT I did notice a more fluid powerband if that makes any sense.
Basically when I got on the gas there was a more even & gradual acceleration.
It made shifting through the 6MT easier.
Old Jan 13, 2011 | 10:41 PM
Reidonly's Avatar
Here is a before and after dyno of my '05 coupe 6MT with the HR y-pipe.
Old Jan 18, 2011 | 04:48 PM
^LOL! Case and point!
Old Jan 18, 2011 | 04:54 PM
TougeMonsterG35's Avatar
wtf i just did a 07 z tube/HR y pipe install on my 04 coupe and it sounds a little bit louder but nothing at all like that CB coupe. i wanna sound bassy too
Old Jan 20, 2011 | 02:21 PM
ConradoR's Avatar
I got this done after several months looking for the right used Y pipe.
The results were not amazing, but enough to make me not regret it.
The powerband improved as mentioned above. Also, the minimal rasp I had from my OE YPipe under hard acceleration went away.
I belive the HR Ypipe will be more beneficial flow wise once I install the Motordyne ART pipes, since I believe that whatever flow I marginally improved with the Y pipe is still being clogged up by my OE cats.
Bonus Round: Before after pic
Before
After
Comparison:
Old Jan 20, 2011 | 04:01 PM
^^^ I'm looking into a new high flow mid pipe for a little more growl but idk 260 shipped is kind of a lot. My Y came out of a 07 Z. What did yours come out of?
Old Feb 1, 2011 | 03:52 PM
saywat?'s Avatar
ugh so wats the consensus on this mod? worth it? or not really? or only worth it if ur getting the pipe for super cheap like $50?
Old Feb 1, 2011 | 05:34 PM
ConradoR's Avatar
07 or 08 Hr Nismo Z, not sure which one but both have the same Y-Pipe and will do the job.
To Saywhat:
I believe overall it was worth it, as long as you're not expecting this swap to give you major performance gains. The only major difference I saw was helping smooth the flow across the mid RPMs
Old Feb 1, 2011 | 05:36 PM
saywat?'s Avatar
seems like the sedans will hear/feel more of the difference then the coupes. atleast thats wat im noticing reading thru that 55 page post lol. starting to think its more of a sedan mod then a coupe mod
Old Feb 3, 2011 | 07:01 PM
dwrecckk's Avatar
I had this on my car for about a year before going to HKS Rep + Magnaflow X-pipe. I'd say that it makes the sound maybe 10% louder, not very noticable at all. Perhaps slightly deeper, but it smooths out the throttle tip ip a bit. Not a bad mod, but not worth more than 100 dollars to me if you're buying it for sound. My entire exhaust with the new xpipe + welding and bending for fitment, cost less than 500 and gives substantially more power than just a y-pipe. Also, sounds great as well. :]
