Notices
Seat heater "high" not working?
Old 02-05-2017, 08:50 PM
LowCoupe's Avatar
04 coupe.
I recently bought the car. If I push the button forward, towards the high setting, only the low setting light comes on. (same thing happens when I push the switch the other way) Eventually the seats get slightly warm. It takes about 10 mins. Both switches do the same thing. Is the high setting not working or does the other light not light up? Or do our seat heaters just suck?
Old 02-07-2017, 02:26 PM
G2B35AGN's Avatar
I have an 06 sedanX. I know the interiors are different between 04 and 06, but in the 06 there is only one light no matter which way you toggle the switch. It takes a little while for them to warm up. High can get pretty warm after a bit, but the area of coverage is pretty limited and seems spotty. So while I have no comparable experience with heated seats, I kinda feel like our seat heaters just suck.
Old 02-07-2017, 06:26 PM
Deepdiver's Avatar
^ +1
Old 02-07-2017, 08:35 PM
BradMD_96's Avatar
[QUOTE=LowCoupe;7094101]04 coupe.
I recently bought the car. If I push the button forward, towards the high setting, only the low setting light comes on. (same thing happens when I push the switch the other way) Eventually the seats get slightly warm. It takes about 10 mins. Both switches do the same thing. Is the high setting not working or does the other light not light up? Or do our seat heaters just suck?[/QUOTE
http://www.6mt.net/forum/g35-coupe/3...ats-work.html]
Forward is High, Back is Low
I'm in FL and actually use them on the cold mornings we're having now but I can't imagine them being much help in proper cold whether
