Lamp Replacement Guide
Old Oct 9, 2009 | 06:17 AM
  #46
SteveZ's Avatar
there now we can see the pic
Old Oct 9, 2009 | 11:33 AM
  #47
Marlin's Avatar
Originally Posted by SteveZ
Pretty much, you should have low beams plus running lights - exactly the same thing as if you manually turned the switch to headlights on low beam, no fogs. Well, except like my car, your side strip light is out on at least one side. I still need to do mine, too!
The reason I'm asking is in the tutorial for replacing the lights I recall reading that the bottom light is the low beam.. plus it makes sense since the light looks weird without the bottom on lol
Old Oct 9, 2009 | 08:40 PM
  #48
SteveZ's Avatar
Weird. No, the top which is pure HID is low beam. Just in case I was dyslexic I just checked my 2004 in the driveway. Low beam top lights are on, the HID's. High beam adds a bright Halogen light on the 2004 from the lower part.
If it's wrong then my car has been wrong from Day 1 back in Nov 2003. I am the original and only owner. But you'd be running 90% of the time not using HID's on the 2004 if the bottom was low beam.
The bottom light is your "fog" light too, which makes a lot of sense as it puts down a little more yellow spectrum beam on the road right in front of you. High mounted fogs would be useless.
The original paper says "High mounted Xenon HID Headlights":
HTH
Old Oct 9, 2009 | 08:42 PM
  #49
SteveZ's Avatar
Here's the rest for the incurably curious, I forgot the auto on (which I never use, lol) was part of the PP:
Old Oct 10, 2009 | 12:49 AM
  #50
Marlin's Avatar
Thanks alot Stevez. I guess I'm good. Just replaced the bulbs for the clearance strip today. Everything is now good.
Thx!
Old Oct 13, 2009 | 09:34 PM
  #51
blackhat5's Avatar
What bulb goes in the clearance light? The long skinny strip light down the side of the headlamp on the 05 G35 coupe?
Old Oct 13, 2009 | 09:44 PM
  #52
Rhino_111's Avatar
Already answered on your other thread. 168s
Old Oct 14, 2009 | 05:11 AM
  #53
huan351's Avatar
Anyone know where to get the high-mounted stoplight?
Old Oct 14, 2009 | 06:01 AM
  #54
SteveZ's Avatar
...and in this thread already, too. 168/198, same.
https://g35driver.com/forums/4484590-post37.html
Old Dec 29, 2009 | 04:22 AM
  #55
huan351's Avatar
Any one know the 04 G35 Couple Glove Box light bulb size?
Old Jan 31, 2010 | 05:29 PM
  #56
G35OD1955's Avatar
How do you remove the maplight cover on a 05 sedan?
Old Feb 6, 2010 | 06:37 AM
  #57
VinhFTW's Avatar
Can you use the 06 low beam bulb on an 05 G?
If so, what would be the difference in looks.
Old Feb 8, 2010 | 01:13 AM
  #58
JizZLe23's Avatar
subscribed!! thanks...
Old May 7, 2010 | 01:31 PM
  #59
dankG35's Avatar
168LL SYLVANIA ,
do these work as good replacement lights for the light bulb in the rear license plate?
I drive a 2008 G35 Sedan...please PM me and know if it fits well~ anybody~
Old Jun 14, 2010 | 10:06 AM
  #60
Italia586's Avatar
Where is the 2007 Sedan Lamp Replacement Guide? Nobody wanted to help out with that huh????
