Passenger low beam wont work
on
http://www.nicoclub.com/service-manu.../Coupe/2004/lt
HEADLAMP OPERATION
Low Beam Operation
With the lighting switch in 2ND position, the BCM receives input signal requesting the headlamps to illuminate.
This input signal is communicated to the IPDM E/R across the CAN communication lines. The CPU in the
IPDM E/R controls the headlamp low relay coil, which when energized, directs power
to 15A fuse [No. 76, located in IPDM E/R]
through IPDM E/R terminal 20
to headlamp RH terminal 3, and
to 15A fuse [No. 86, located in IPDM E/R]
through IPDM E/R terminal 30
to headlamp LH terminal 3.
Ground is supplied
to headlamp RH terminal 4
through grounds E17 and E43
to headlamp LH terminal 4
through grounds E17 and E43.
With power and ground supplied, low beam headlamps illuminate
Use a multimeter to test
Xenon Headlamp Trouble Diagnosis
AKS00ACP
1.
CHECK 1: XENON HEADLAMP LIGHTING
Install normal xenon bulb to corresponding xenon bulb headlamp, and check if lamp lights up.
OK or NG
OK
>> Replace xenon bulb.
NG
>> GO TO 2.
2.
CHECK 2: XENON HEADLAMP LIGHTING
Install normal HID control unit to corresponding xenon headlamp, and check if lamp lights up.
OK or NG
OK
>> Replace HID control unit.
NG
>> GO TO 3.
3.
CHECK 3: XENON HEADLAMP LIGHTING
Install normal xenon lamp housing assembly to corresponding xenon headlamp, and check if lamp lights up.
OK or NG
OK
>> Malfunction in starter (boosting circuit) in xenon headlamp housing. (Replace xenon headlamp
housing assembly.)
NG
>> INSPECTION END
Telcoman
druggist
03-15-2016 11:44 PM
RINO
01-13-2012 07:52 PM
