Tian's Build Thread
If you look up 360 Forged F430 it's exactly the way it seems in the pictures and videos
http://www.streetfire.net/video/ferrari-f430-scrape_1218547.htmhttp://www.streetfire.net/video/360-forged-ferrari-f430-aka-rolling-death_381062.htm
We sprayed a 4x2 piece of sheetmetal so it's kind of hard to catch the effects
but when there is no light its a dark gunmetal but when the sun hits it directly
it's almost Platinum silver and it blinds you.
I will try to make a small video to show you the effect
http://www.streetfire.net/video/ferr...pe_1218547.htm
http://www.streetfire.net/video/360-...ath_381062.htm
<object width="400" height="300"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=11385189&server=vimeo.co m&show_title=1&show_byline=1&show_port rait=0&color=&fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=11385189&server=vimeo.co m&show_title=1&show_byline=1&show_port rait=0&color=&fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><p><a href="http://vimeo.com/11385189">New Color</a> from <a href="http://vimeo.com/user1964384">Glex25</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
If anyone is familiar with LEDs please check this thread out https://g35driver.com/forums/lightin...eded-fast.html
Also, I will be placing digital gauges on the A-pillar. Looking for a two pocket pillar if anyone knows where I can locate one LMK. Can anyone recommend an accurate brand of digital gauges that would be great. It will be for a NA car and then carry it over for when I go FI. Any recommendations on what gauges to run on an NA car? Currently thinking AF ratio and oil temp/pressure?
As far as gauges run a AEM wideband and since you staying NA for a awhile I would say run a AEM Oil pressure gauge if you can.
the paint code I'm going with is 159650
All Grigio Silverstone is metallic
I want something off the shelf in case i need to respray in the future
#30
