Drag NHRA, IDRC, IHRA, NDRA
Launching in a 5AT
Old Jul 7, 2006 | 11:37 AM
arjunz's Avatar
Launching in a 5AT
Last night.. i was trying to launch my 5AT by Brake torquing....with VDC off..... for some reason... it felt like VDC was still on.. even after i had it turned off..usually i could chirp my tires before taking off... it felt like i actually slowed down... and the RPM dropped all the way back down before the car actually started moving.... Does anybody know why this could have happened?
Old Jul 7, 2006 | 02:03 PM
rcdash's Avatar
Brake torque launching takes a bit of practice - no doubt. When you release the brakes a sudden load (the wheels/tires) are placed onto the engine and will cause a drop in rpms. If you drop below the stall speed (2600 rpms), you will not have an instant launch as the engine will not be directly coupled to the driveshaft (rather the torque converter must spin past 2600 rpms again).
I have had the best success by doing a "mild" brake torque launch. I hold the brakes lightly. Then at launch time, I stomp on the gas, and release the brake about a half second later as I feel the car move (that's the driveshaft turning the wheels despite the brakes being "lightly" applied).
Old Jul 7, 2006 | 04:34 PM
arjunz's Avatar
What if it doesnt let u ... rev upto 2600 rpm?..... it wasn't letting me ..with VDC off.... i'll try "mild" brake torque launch... thanks for your reply
Old Jul 7, 2006 | 04:38 PM
akachi's Avatar
sry.. but what's brake torque launching?
Old Jul 7, 2006 | 07:08 PM
r0csfinest's Avatar
I think its when you hold down the brake a lil and step on the gas and let go of the brake
Old Jul 8, 2006 | 12:22 AM
akachi's Avatar
what's that suppose to do?
Old Jul 8, 2006 | 01:35 AM
arjunz's Avatar
It helps you launch better... off the line ...
Old Jul 9, 2006 | 12:02 AM
DaveB's Avatar
You're loading the torque converter which actually multiplies the torque and makes the car launch much harder. Without doing this technique, the 5AT will pull higher 2.3 60 foots. In my car, that's the difference between running a 14.7 or a 14.3.
Old Jul 10, 2006 | 12:59 PM
G35_TX's Avatar
Strange, I always got faster time on my auto Maxima when I just went from the brake to the gas. When I loaded the TQ converter it took off slower.
But of course it was a different car.
Old Jul 10, 2006 | 05:19 PM
baileyrx's Avatar
our cars computer decreases throttle by 30% when the brake is depressed. Its a safty feature.
To get full power you'll need a brake bypass switch! They're available from a couple of members on this site or my350z.com
Old Jul 10, 2006 | 05:32 PM
Jeff92se's Avatar
Red Card Crew
Wow. Nice info
Old Jul 10, 2006 | 07:17 PM
baileyrx's Avatar
jeff,
noticed your sig:
...how do you like the autoenginuity odbII sacnner?
...how does it work with our nissan computer?
...how much did it cost you?
i'm looking into getting some type of scanner
not to highjack this thread but, pm me when you get a chance
Old Jul 12, 2006 | 03:42 PM
Sportcoupe35's Avatar
I have the vortech on my car with 370whp and 300 torque.
I took my car to the track for the first time.
I had no idea what I was doing.
No burnout...I just rolled up to the light...turned green (had the vdc off and left it in drive) and I just slammed on the gas. I did the quarter in 13.9. I think that if I can figure out how to launch my car...I should be low low 13s.
I just gotta try this technique. I only got to do one run cuz some mustang blew its motor all over the place so it took like 1.5 hours to clean up.
Next time I go ... I gotta try this.
It was like 80 degrees by the way.
Old Jul 22, 2006 | 04:38 PM
arjunz's Avatar
^u shud have done better... let us know what times u pull of when u hit the track next
Old Jul 22, 2006 | 07:26 PM
DaveB's Avatar
I've done all the brake mods (yanking fuses, disconnecting the yaw sensor, etc) that do the same thing as the brake bypass switch. There's absolutely no differences in the way the car launches. It still feels like something is holding it back until 3000-3500rpms comes around.
