homelink?
Old Oct 22, 2004 | 11:46 PM
juggernaut's Avatar
homelink?
can it be added later? anyone do it?
thanks
Old Oct 23, 2004 | 02:10 AM
Msedanman's Avatar
O.F. Administrator
Re: homelink?
Apparantly, you can convert to a homelink equipped rear view.
See the dealer.
C.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Oct 23, 2004 | 03:51 PM
juggernaut's Avatar
Re: homelink?
really? great thanks!
is the homelink in the mirror normally or is it on the visor? thanks
Old Oct 24, 2004 | 01:57 PM
03G35Black's Avatar
Re: homelink?
the older models, like the i30 and qx4 had them in the sun visor. but i believe all the new infinitis have them in the rear view mirror.
Old Oct 24, 2004 | 07:24 PM
juggernaut's Avatar
Re: homelink?
thanks!
can someone take a pic? how does it get power?
Old Oct 24, 2004 | 10:42 PM
P_Diddy's Avatar
Re: homelink?
A company called Gentex makes the rear view mirrors w/ Homelink. Check out the pic, it's exactly the same! I don't know how you would wire it up though.
http://store1.yimg.com/I/aaaremotes_1814_16499492
2004 6MT DG/G Coupe | Premium | Aero Kit | ClearBra | See profile for pix
Old Oct 24, 2004 | 11:39 PM
juggernaut's Avatar
Re: homelink?
gentex you say... thanks.
i was curious to find out how they get power though...hmmm
Old Oct 26, 2004 | 10:06 PM
mikeinaustin's Avatar
Re: homelink?
the installation manual is on their site. for the homelink auto-dim model, its just one 12-volt power wire and one ground wire.
now if you get the mirror directly from infiniti it will probably come with the actual connector attached so you can simply plug into the existing wiring harness (under dash). i can't promise you this but toyota also uses gentex and thats how they do it. basically a 5 minute mod.
Old Oct 27, 2004 | 01:31 AM
juggernaut's Avatar
Re: homelink?
cool, thanks for letting me know.
Old Oct 27, 2004 | 09:31 PM
avs007's Avatar
Re: homelink?
I bought the autodimming homelink gentex from a different site for my other car. It is the exact mirror in my G35. (Gentex is the OEM)
Anyways, it will come with the wiring harness. I looked at the mirror in my G35, it is the exact same wiring harness.
But anyways, it is actually 3 12v power lines, not one. One is for autodimming (hot with ignition), one is for homelink (always hot), and one is to undim when in reverse (hot when tranny in reverse).
Only took me like 5 minutes to install in my other car.
Old Oct 27, 2004 | 10:04 PM
wizawuza's Avatar
Re: homelink?
avs, you did hte 3rd "reverse" wire in 5 minutes with your other car? what car was that, and how'd you do it?
Thanks
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Oct 28, 2004 | 10:47 PM
avs007's Avatar
Re: homelink?
It was for a pontiac GTP, that I was replacing a busted autodimming mirror, with a new homelink one. I didn't connect the reverse power lead, because the Pontiac came with a different brand autodimming mirror. So it accomplished the same thing, by having a +12v line that was hot with the ignition, but went cold when put in reverse.
I just cut off the other power line. (I had to cut off the harness, and transplant it, becaues the other car had a different harness. I'm not sure if G's without the premium package still have the wiring harness installed for the mirror, if so your install may be really easy. All I had to do was run an additional power for the homelink. I just took down the headliner, and ran the wire up there, behind the pillar, and into the fuse box, where I just connected it to an AUX port that was always hot. When all was said and done, it looked factory installed.
Old Feb 18, 2005 | 12:47 PM
tonybon's Avatar
The g35 does not use the reverse function. The third wire is gnd.
Old May 24, 2005 | 02:38 PM
HipHopPro's Avatar
I'am looking to get a Homelink rear view mirror put in my ride, but the dealer said it can't be done if it didn't come with it. Is this true? I have a 2004 coupe, and I need one.
Old May 24, 2005 | 03:40 PM
WRAH's Avatar
WRAH
This is bull$hit because all this mirror needs is 12v power source! You can add it easy!
