MREV-V2 Added to 0.5” MD Cooper Iso Thermal Plenum Spacer
Old May 6, 2006 | 09:59 PM
dovla's Avatar
This is on 2004.5 G35-MT.
Beside suspension and title mods, car have K&N drop-in filter, Z-tube and CrawfordZ cats.
Lower plenum installation was done while the car was strapped to dyno.
Coolant temperatures, Cipher showed as 87 C at the beginning of 3 pre-install pulls and 85 C at the beginning of 3 post-install pulls.
Tomorrow I will try to post Cypher logs, have to go now.
One-step forward, two steps backward. Happy moding!
Old May 6, 2006 | 10:53 PM
Boston's Avatar
Great post, good stuff!
Old May 6, 2006 | 10:56 PM
papagz's Avatar
thats a pretty high dyno there. great numbers.
Old May 6, 2006 | 11:35 PM
bigwilly's Avatar
So MREV2 does basically nothing for those with 1/2" spacers?
Old May 7, 2006 | 12:11 AM
99atlantic's Avatar
aside from raising the A/F by almost a full point under 4K RPM, doesn't look like it does anything to me (to warrant the cost)
Old May 7, 2006 | 10:24 AM
Hydrazine's Avatar
Thanks for posting your results Dovla!
Your $100 rebate is on its way.
Now we need more dynos. Many more on a range of setups to see what the possibilities are.
Tony
Old May 7, 2006 | 10:49 AM
Andy2434's Avatar
I wonder if this lastest MREV 2 lower collector and 1/2" spacer dyno test data is consistant or similiar with the previous MREV+ and 5/16"/1/2" spacer test data? If I remember correctly the 5/16" spacer did much better and thus was the preferred and recommended size to compliment the MREV+ lower collector. I guess I will find out soon enough.
Old May 7, 2006 | 01:37 PM
OCG35's Avatar
do you really think 3/8 of an inch would make a notable difference?... I know there are dynos out there, but how many of them are same day, same dyno, same conditions - one 1/2" and one 5/16"... there isn’t a whole lot of difference between the two and I find it hard to believe TQ or HP would be all that different... Maybe there is data out there to the contrary... If I remember correctly Tony made the 5/16" for clearance not performance.
Old May 7, 2006 | 01:57 PM
G35StrongMan's Avatar
Cool
Tony,
I was #116 on Friday. I currently have a Stillen airbox, Z-tube, 1/2" spacer with ISO Thermal Kit, Invidia G200 exhaust with custom H-pipe, and a KJR LW crank pulley.
I plan on doing before and after dynos of the MREV-V2 install, same day.
Old May 7, 2006 | 03:36 PM
OC 350GTCoupe's Avatar
The 5/16 spacer averages more HP gained throughout the whole RPMs then the 1/2 inch spacer. Thats also why its more popular.
Old May 7, 2006 | 03:54 PM
dovla's Avatar
You mean on Rev-Up?
Old May 7, 2006 | 04:10 PM
dovla's Avatar
Graphs from Cypher logs made during Dyno for lower plenum swap
So many graphs, it is hard to weed out discrepancies.
One thing that is interesting is how this freaking ECU adjusted injector pulse from 2200 RPM to 4400 RPM with MREV-V2 on my car. Which is good thing because tuning should be easier now.
Hey, I need at least some justification for the swap
Pre_Install:
Post_Install:
Old May 7, 2006 | 04:54 PM
Andy2434's Avatar
The 5/16" spacer performed and tested the best with the original MREV and MREV+. This said combo was the one, which was recommended by Tony with regard to the original MREV set-up. I am just wondering if the same holds true for the new MREV 2. Remember, back then the MREV was for the RevUp engines only and the non RevUp engine owners had their choice between the different sized spacers. Now, with the new MREV 2, everything has changed for all of the VQ engines. The next month or so should afford and prove to be quite informative and productive, as well.
The 3/16" difference in height between the 2 spacers does make a difference in the total volume of the plenum . . . Especially, when you are already working with a small volume to begin with. I'll find out for myself in short time with regard to the MREV 2 and the 5/16" spacer.
Old May 7, 2006 | 08:00 PM
OCG35's Avatar
You should take a look at the Winter 2006 issue of Sport Z Mag (which was actually 2005 - it's issue 1 of 2006)... It is the only full comprehensive dyno comparo of the two spacers I have seen... from 2000-3500 rmp they are nearly identical, 1-2hp & tq diff here and there... the only time the 5/16" shows notable difference is at 4000rmp and that’s only by 3hp & tq... from there thru 6400 again it's close but with the 1/2" squeaking out 1-2hp & tq here and there.
Let's not spread bad info here folks... As for 5/16" vs 1/2" WITH MREV-2, we shall wait and see. I stand by the thought that there won’t be a significant difference.
BTW, the reason 5/16" is "more popular" is because 1/2" is no longer in production.
Old May 7, 2006 | 08:44 PM
DaveO's Avatar
The part of the shoot out you're talking about was done using a stock 287HP 6-speed 350Z. IMO adding intake and exhaust mods may change the "winner".
Also Motordyne's 1/2" spacer is still available and there's no plans to discontinue it at this time.
DaveO
