-ve camber
-ve camber
I installed Tanabe coilovers like 1 month ago after getting them installed I waited like 2 weeks and then did an alignment and height adjustment but the problem the rear left wheel had - 1.7 camber and the other side was fine and guy who did the alignment couldn't get that -ve camber into specs (it's a pro shop) although I have a camber kit the guy spent like 1 hour to fix and nothing why would be the reason? And also that same wheel is always lower than the other I mean after the height adjustment that wheel got lower more than the others is there something wrong with the shock or bad installation?
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
