| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
#31
Just got my 2005 5AT Coupe! Wheel Upgrade Question
Hi all! I just picked up my 2005 G35 coupe last week, and is still getting used to driving with so much more power (upgraded from a 2001 Mazda Miata)... I am looking into buying new wheels and tires to replace the factory 6-spoke rims (standard, non-Brembo brakes). From the sticky it seems like these are the specs:
Front: 17"x7.5" +30mm offset Rear: 17"x8" +33mm offset I am looking into either 18" or 19". The site I am shopping from gave me these options for 18" and 19" wheel/tire combinations: 18" OPTION ---------- FRONT: 18"x8" 40 offset with 225/45YR18 REAR: 18x9.5" 35 offset with 255/40YR18 =OR= FRONT: 18"x8" 20 offset with 225/45YR18 REAR: 18"x9.5" 20 offset with 255/40YR18 19" OPTION ---------- FRONT: 19"x8" 40 offset with 255/35YR19 REAR: 19x9.5" 35 offset with 285/35YR19 =OR= FRONT: 19"x8" 20 offset with 255/35YR19 REAR: 19"x9.5" 20 offset with 285/40YR19 My question is that if the factory offset is 30 what are the effects of going to 40 (that would make the wheel "stick out" of the wheel well, right?) versus 20? I would like the wheels to not stick outside of the well if possible... Should I stay "conservative" regardless of wheel size to go with the +40, +35 offset combination that is closer to the +30, +33 instead of the +20? I am also trying not to affect the performance (speedometer/gear ratio) too much (not planning on upgrading the suspension yet), so I am wondering if most members are sticking to 18" or all out to 19"? The wheel I am planning on getting is the Petrol Octanes: http://www.petrolwheels.com/wheel_st...eel-octane.php Sorry for the long post - any help anyone can offer would be greatly appreciated! Last edited by schlaulau; 09-26-2007 at 04:27 AM. Reason: typos |
#32
Someone should post the weight for the wheels too... just for fun...
#33
Quote:
I just picked up a set of oem 19's for my new spares so I'll weigh them when they come in.
__________________
ONE FUN SEDAN!! MY CAR (LINK) Detailed Image | Greddy Twin Turbo & Built Motor by UMS Tuning = 649whp/651wtq | Rotora (12/4pot) | IForged | Quad Projector Retro | 1-off Dual 3", Dual Muffler Turbo-back Exhaust by Nichols AutoFab | NITTO | SPARCO | |
#34
Quote:
#35
Crap, I forgot all about that when I got mine. They are light, very light for sure. I was shocked when I took them out of the boxes.
__________________
#36
sizes for 2008 G35x S?
Anyone know what the wheel/tire details are for a 2008 x sport? It just came out and must have 4 identical wheels, but it comes with 18" rims.
Thanks! |
#37
Quote:
#38
Questions about the 2008 G35x Sport.
-Is there any difference between the 2008 G35x Sport package vs. the G35 Sport rear drive train besides the fact that the sport is RWD and has bigger brakes? -Are suspension components the same in both cars? If I go ahead and buy a G35X sports package, I may want to buy another set of rims, the 7.5" x 18" and 8.5" x 18" rims (from the G35 sport) for summer use only and have the 4 7.5" x 18" rims from the G35X Sport for winter tires. |
#39
Does anyone know the size and offset of these wheels?
![]() I think they might be 17x7, but not sure. They are from a 2004 g35 sedan upgrade package. Thanks. Last edited by kgallerie; 03-12-2008 at 12:45 PM. |
#40
Quote:
My understanding is that the sport package on both cars gave you the following:
I'd still like to know the actual specs on the G35x S wheels - numbers?! Cheers, jtebb |
#41
Quick question the stock 17s on the 05/06(7spoke) are the same as the 18s from the coupe? Only difference is that they are 18s with a 35offset correct? If so what size spacer would be needed to fit it on a sedan and what would be the best size tire for it 245/50/18?
#42
I have a 2003 sedan 6 spoke OEM and on the back it says 17x7
with a 45 offset, does not match the numbers mentioned in the sticky.. GBoy |
#43
Do we know the weight of all OEM wheels? In particular, I'd like to know the weight of my 06 sedan wheels (I believe they're 7-spoke)
__________________
Brian - '06 G35x
#44
Just what I needed
Thanks bud. This is just what I needed.
#45
07-08 Sedan 18" split 7-spoke Sport wheel weights:
http://g35driver.com/forums/tech-07-...el-weight.html Front: 23.7 lbs Rear: 22.4 lbs
__________________
2008 Ivory Pearl G35S 6mt Premium | 2007 Copper Red CX-7 Sport AWD |
| Tags |
| 18, 2004, factory, g35, inch, oem, rim, rims, sedan, spoke, sport, stock, weight, wheel, wheels |
| Thread Tools | |
| Display Modes | Rate This Thread |
