G35 Factory/Oem Wheel Sizes & Offsets
Rating: Thread Rating: 4 votes, 5.00 average.
  #121
Old 08-07-2013, 06:33 PM
websterzx10r's Avatar
i am posting for the first time. Apologize if its the wrong thread. I am in need of 1 19" 8x0 front Ray rim for a 2006 infiniti coupe. Mines is cracked and was rewelded when i brought my car and it opened up and is leaking air out. Am in the new york city area can use some help please.
  #122
Old 08-07-2013, 10:45 PM
junl350z's Avatar
You did post on the wrong thread but that's ok.. Check out the MARKETPLACE Forum... ...
  #123
Old 08-29-2013, 09:32 PM
allanz's Avatar
Wheel Upgrade g35x
Hi. I have a question. I don't know anything much at all about cars. :-/
My car needs new tires, but i want to upgrade the rims, so i'd figure i buy both at the same time.
I have a 2007 g35x with factory everything. Rims are the 17 inch ones that came with it.
I like these other rims i saw on ebay. The seller is selling them with tires and am wondering it they will fit my g35x.
Sellers description:
OEM INFINITI G37s Factory Stock 2010 WHEELS BY ENKEI.
TIRES ARE BRIDGESTONE BLIZZAK RFT 90 % TREAD 245/40/18 ALL AROUND..WHEELS ARE IN GOOD CONDITION WITH MINOR SCRATCHES, NO DENTS STILL LOOKS GREAT.. .HYPER SILVER FINISH 5 BOLT PATTERN 5x114.3, FRONT WHEELS ARE 18X7.5, REAR WHEELS ARE 18X8.5.... 3 rear an 2 front= 5 wheels an 4 tires
Any advice would be greatly appreciated.
  #124
Old 10-05-2013, 12:30 PM
releasedtruth's Avatar
Have a chance to buy (4) Rays 19s, but they are all Rears (19x8.5 33mm). I ran M45 19s with spacers for years. Does the the 9mm less inner clearance matter at all?
I can stagger 245 and 255 or run all 245-40 like on the M wheels so no worries there.
Thanks!
  #125
Old 12-22-2013, 08:19 PM
iamjansport's Avatar
Hi! I was wondering if these are OEM wheels?
  #126
Old 12-22-2013, 10:14 PM
Frankieg35's Avatar
Doesn't look like it..
  #127
Old 12-23-2013, 01:09 AM
VQ35DE-G's Avatar
If they're 18s, they're the sedan OEM wheels that are NOT forged but look like the 19" forged Rays from the coupe.
  #128
Old 11-09-2014, 01:25 AM
QX1's Avatar
QX1
QX1 is offline
G35 06 wheel 18' offset
Can i use 06 g35 sedan 6MT 18x7.5 wheels with 48 offset?
Originally Posted by Darkness_S14
I was surprised it took me several searches to find this info, so here it is all in one spot (someone please post the offsets for the new 2005 sedan wheels as I still wasn't able to find that info)
17" 5 spoke (model??)
Front & Rear: 17"x7" +40mm offset 5x114.3mm (5x4.5in) bolt pattern (aka PCD)
17" 6 spoke (model??)
Front: 17"x7.5" +30mm offset
Rear: 17"x8" +33mm offset
17" 7 spoke (2005+ Sedan std)
Front & Rear: 17"x7" (+45mm)
18" 7 spoke (2003/2004 optional 2005+ Coupe std)
Front & Rear: 18"x8" +30mm offset
18" 5 split spoke (2005+ Sedan optional)
Front & Rear: 18"x7.5" (+45mm)
19" 5 split spoke (2005+ Coupe optional)
Front: 19"x8" +30mm offset
Rear: 19"x8.5" +33mm offset
17" Wheels - double 5 spoke alloys (2007 Sedan)
- Front & Rear - 7.5" x 17" with 45mm offset with 225/55R17, V rated all season tires.
18" Wheels - split 7 spoke alloys (2007 Sedan)
- Front - 7.5" x 18" with 45mm offset with 225/50R18 W rated summer performance tires.
- Rear - 8.5" x 18" with 50mm offset with 245/45R18 W rated summer performance tires.
  #129
Old 01-09-2015, 10:09 PM
BostonBrian's Avatar
19 inch Rays
Hi there, a couple of days ago I hit a nasty pothole that bent both of my passenger side 20's. Expensive and stupid mistake. One that couldn't be avoided. So I went on Craigslist and found some Rays 19 inch. I was all exited to get em home I didnt realize that all 4 rims were rears 19x8.5 33mm. Do you know if i can still run these on a 04 coupe with bembros without causing damage to the front. Also what size tires you recommend for the front. Being that they are all rears around.Im not sure if i can use 225/40 in front. Any help would be appreciated.
  #130
Old 01-19-2015, 11:58 AM
Freddy Arellano's Avatar
i have a 2006 g35x with the stock 17" 7 spoke (2005+ Sedan std)
Front & Rear: 17"x7" (+45mm).
i want to get another set of wheels for the snow since im from chicago. i found 17" double 5 spoke alloys (2007 Sedan) Front & Rear - 7.5" x 17" with 45mm offset with 225/55R17.
i wanna know i can just slap them on or do i need do anything like roll the fender because of the different width?
  #131
Old 12-07-2016, 11:43 PM
3000vr4tt's Avatar
hm so on a stock rim for the 05 g35x guys whats the widest tire anyones put on staying on a 17 inch tire
  #132
Old 12-15-2016, 05:08 PM
Dylan Hernandez's Avatar
Question about width of tire
So I have a 2004 g35x sedan and I have the 17" stock rims right now but was looking at 18x8 rims online that, fro mm the website, say they fit my Car. What I don't understand is that if I choose to add some tires in to make it a package it offers 245s?? My car currently has 215s and would that mean my rims only fit 245s? I'm so confused and don't think some 245 tires would fit my car, although I do know they fit the coupe, any help???
  #133
Old 12-22-2016, 05:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
I'm confused by your post. When you say 245 wouldn't fit your car are you talking about the 17" stock rims or the 18" rims you're looking at? 245 is a measurement of width while the 17"/18" is a measurement of height so they have nothing to do with each other. The width of your wheels will determine if a 245 will fit on your stock wheels. I believe yours are 7" wide so 245's will fit but will bulge the sidewalls a bit.
  #134
Old 11-15-2018, 05:37 PM
jparker7269's Avatar
2004 G35 DE coupe
I have an 04 coupe lowered on Hotchkiss springs. Just got the car so dont know the actual lowered amount. I'm guessing the guy pulled his wheels and sold it with sedan 17x7 wheels that are on it now. I found some 07+ sedan wheels 18x8.5 +50 offset and 18x7.5 +45 offset. The coupes usually come with 18x8 +30 offset. Will these work and look right or inset too much?
  #135
Old 11-16-2018, 05:40 AM
Blue Dream's Avatar
They'll it but be really sunken in.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: G35 Factory/Oem Wheel Sizes & Offsets
