well first of all when you change the inner lip (behind the face) you INCREASE the offset and then you DECREASE the offset by bigger outer lips so therefore you would be not really going anywere
so i have no idea how you got from a 8 +50 to a 10 +0 and 12 +0 unless you're using spacers
and your math is wrong, you need 4 outer lips and 4 inner lips (for 3 pc wheels) and given 300/piece =2400, i have a hookup for 200/a piece but even they say its not worth it to replace the inner lips
only time you want to mess with the inner barrel is if you want to do step lips from reverse lips
Quote:
can someone confirm this? Originally Posted by eurodre
if you change inner barrel from 6" down to 5", you are actually decrease the offset, not increase
this has been confirmed, official, whatever you want to call it
and so you're basically taking off 60mm off the offset then putting it back on with the same width inner lip
LIP not barrel, a barrel is when the wheel is a 2pc when you have the whole barrel and the face
and enough crowding my thread, with all respect go learn somewhere else
this has been confirmed, official, whatever you want to call itand so you're basically taking off 60mm off the offset then putting it back on with the same width inner lip
Free bump for you bro :thumbup:
