FS: Sevas S7 w/tires
firozu- i think these will fit on sedan , i have seen other sedans with more aggressive setups. I didnt use long studs or spacers. The only thing you will have a staggered look in the rear, i know right now u have all the same size on ur ride cuz sedans dont run staggered fitment. I am checking the offsets as we speak.
That will be a problem then. Im looking at a set of Volks that are 20x10.5 +23 rear and only way I can fit them is to stetch the rear tires and about a 10mm pull and ill still run around -3 out back.. so imo offset is to low for him.unless he is willing to get new tires, rear camber kit :-( sorry
I have yet seen a sedan in florida with lowlow offsets nor dropped enough
