FS: Fs:bnib works vsxx burning black
#36
Just my 2 cents bro!!!
You should be able to get them re-drilled to 5X112 for less than $200.00 (and you don't even need inserts going from 114.3 -> 112)!
Hubs on the S5 are 66.6...so if these hub holes are bigger ..run rings! If they are smaller...get them bored out (again...should be less than $200.00 for all 4).
These offsets will fit on your S5 as is (if you slam and camber it...there will be minimum poke). They will fit like the wheels on ROBZONE's A5!
![Driving](https://g35driver.com/forums/images/smilies/driving.gif)
blues (09-14-2011)
#37
These offsets will fit on your S5 as is (if you slam and camber it...there will be minimum poke). They will fit like the wheels on ROBZONE's A5!![Driving](https://g35driver.com/forums/images/smilies/driving.gif)
poktanG35
Engine - Exhaust
10-26-2015 03:32 AM
