FS: BRIGHT! Full LED Conversion Kit! Includes ALL your interior bulbs, easy mod!
Rating: Thread Rating: 5 votes, 5.00 average.
Old Jan 19, 2013 | 02:35 PM
  #211
jdmcoupe07's Avatar
just ordered mine
Old Jan 28, 2013 | 06:12 PM
  #212
Maxypad's Avatar
Let me know when you get Stage 3 white Map lights back in stock! ill but a set right away
Old Jan 29, 2013 | 08:04 AM
  #213
Diode Dynamics's Avatar
We will, thanks!
Paul
Old Jan 29, 2013 | 10:43 PM
  #214
04VQG35sb's Avatar
Just ordered a set for my door lights! hoping it gets here soon
Old Feb 3, 2013 | 01:03 AM
  #215
R6n350GT's Avatar
do you have this lead? the top one in the pic, goes from factory reverse light plug to hid ballast for reverse led kit.
http://www.autolumination.com/images...tions_5_wm.jpg
Old Feb 3, 2013 | 11:37 AM
  #216
Why would you put a ballast on a reverse LED? Ballasts are used only for HID application.
-Garrick
Old Feb 8, 2013 | 02:31 AM
  #217
Frankieg35's Avatar
Do u have an led bulb for the glove box??
Old Feb 8, 2013 | 10:46 AM
  #218
Our notes indicate that a 194 bulb will fit, depending on the length of the stock bulb, here are your options:
http://www.diodedynamics.com/store/i...-size/194.html
Old Feb 12, 2013 | 12:36 PM
  #219
barberdave33's Avatar
Footwell kit
Ive already got my complete LED's installed in the total interior & fogs.. Just ordered the LED single color footwell kit for my sedan. I want the LED's to come on when my headlights are on so I'm planning on splicing through the glove box wiring. My question is, are the splicing kits easy to use and install? And since I'll be using the glove box wiring to spice into will I still need to install a toggle switch? And lastly, will a ground still be needed? THANKS..
Old Feb 13, 2013 | 08:06 AM
  #220
The wiring harness comes with standard quick-splice connectors- please watch the install video to see how it is done. You do not need a switch, but again, please see the video- you would need to plug it in and leave it in the on position behind your dash. You would not need the ground running to the switch, but you do still need the main ground for the kit.
Thank you!
Paul
Old Feb 17, 2013 | 08:02 AM
  #221
frontieragent's Avatar
Tried to order a whole interior LED and it wouldnt let me. Says some items are out of stock but it wouldnt tell me which one(s).
Looking to buy Stage 3 White for 04 Sedan. Looking to buy asap. Lets make this happen.
Old Feb 17, 2013 | 12:27 PM
  #222
Some of our products are out of stock. If you order each product individually (not using the kit product) the page will tell you which items are out of stock. The price will be the same as the kit. Let me know if you need help.
-Garrick
Old Feb 19, 2013 | 11:28 AM
  #223
Maxypad's Avatar
Just tried to order stage 3 white map lights for my 06 coupe and it wouldn't let me go threw your one step checkout??
Old Feb 19, 2013 | 11:45 AM
  #224
Garrick,
When you have all of the Stage 3 lights in for the G35 Sedan in white. Lemme know and Ill order them asap. Thanks
Old Feb 19, 2013 | 11:51 AM
  #225
I do apologize, I will have to look into what might have been causing that for you. Looks like you were able to put it through on Paypal though, thank you!
Paul
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
