Cusco Camber Adjustable A Arms (4 In Stock!!!)
Jun 20, 2006 | 05:13 PM
Cusco Camber Adjustable A arm
Direct replacements for the front A arms and allow you to adjust camber on the front of your 350Z or G35. These employ a special compound rubber busing to ensure smooth operation and minimize noise. The actual amount of camber you can dial in or out will of course vary from car to car based upon suspension setup, rideheight, as well as your tire and wheel combo. However, these should provide more than enough adjustment to bring most any car back into the specs one could want (please note if your car is extremely lowered in front, depending on your particular setup you might not be able to adjust back to factory specs, though you will be able to scale back the total amount of negative camber. We installed these on our own 350Z, which is lowered with Cusco coilovers, and were able to bring the car back to -1.25 degrees in the front.
$395 shipped!
CA TAX WILL APPLY TO CA RESIDENTS
Thanks,
Gruppe-S
510 783 5300
Jul 14, 2006 | 01:57 AM
bump!
Jul 18, 2006 | 03:12 AM
I might be interested in these, and local. By the way, do you guys do alignments?
Jul 26, 2006 | 01:04 PM
Still got these instock? How much shipped to 96818.
Jul 26, 2006 | 08:26 PM
what extreamly low in the front? 2+ inches?
Aug 2, 2006 | 01:20 AM
Quote: I might be interested in these, and local. By the way, do you guys do alignments?
Are you guys afraid of money or something? Hit me back...
