06 350z suspension
Old Mar 23, 2007 | 04:10 PM
Tunerz_Store's Avatar
06 350z suspension
SOLD!!
Suspension has 1500 miles on it. Will drop the sedan 1" and gives superior handling over stock. Rear shocks don't have top hats, you will have to use old ones from your car. $250 shipped plus 3% paypal fees.
Old Mar 26, 2007 | 12:55 PM
Mr.Igor's Avatar
any problems? how was the alignment? i am interested are you ever in the NJ area?
Old Mar 26, 2007 | 02:02 PM
trey.hutcheson's Avatar
Do the fronts have the topmounts already mounted?
Old Mar 26, 2007 | 09:39 PM
didn't have alignment done with this setup. only put 900 miles or less on the setup. I would assume the alignment wouldn't be much different than the other setup I had which was z springs front on oem sport struts and coupe springs in rear with oem sport shocks. my alignment with that setup put the front around -1.1 camber and -1.4 max in the rear with coupe springs. the 06 suspension would only change the rear adding another .5" drop with stiffer spring and better shock/strut front & rear.
Old Mar 26, 2007 | 09:40 PM
fronts are complete. only rears missing topmount and dust boot, which I had to transfer over to the NISMO shock because it didnt' have either.
Old Mar 28, 2007 | 03:45 AM
sale pending.
Old Mar 30, 2007 | 01:11 AM
pics added, still available.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
