FS: Crawford Cast Plenum - $200 + stock plenum
Old Apr 23, 2007 | 07:29 PM
hyperlite21's Avatar
so comparing this to a motordyne spacer which would you benefit mire with as of power gains???
Old Apr 23, 2007 | 07:31 PM
ksj4340's Avatar
Originally Posted by filanj
It is a much larger intake manifold than OEM. This will increase your A/F/R very nicely and give you a decent increase in HP... Not a whole lot, but VERY noticeable.
Should this work with MD 5/16" spacer?
will it fit with spacer?
and with spacer, still will increase HP slightly?
Old Apr 24, 2007 | 12:13 PM
filanj's Avatar
MHO is that this Crawford will rock any MD
Old Apr 24, 2007 | 12:16 PM
filanj's Avatar
As per say running the Crawford AND the MD... I am uncertain of the largest spacer you can run, but if my memory serves me well I do recall a member selling his Crawford with a 1/2" MD spacer sealed to it about 5-6 months ago on here.
I would highly suggest running some sort of AFR as a stated earlier with a combo like that. You do not want to run too lean by accident.
Old Apr 25, 2007 | 12:33 PM
AFR....what is that???
Old Apr 25, 2007 | 12:50 PM
g35rcr's Avatar
air fuel ratio and he wants 200 plus your stock manifold...thats why i mentioned grubbs
Old Apr 25, 2007 | 01:02 PM
Jeff92se's Avatar
Red Card Crew
Technically it should. Problem is the two bolts that hold down the middle of the plenum will no longer reach. You might be okay with the bolts that hold the outside of the plenum.
But the question is why? It's been proven that using larger spacers enters the area of diminishing returns. Using a Crawford and a spacer is essentially like using a HUGE spacer.
You might see a gain up at the very top (I guess). But the question is what will happen to the rest of the hp curve? You will probably lose lowend (I guess).
If you have the spacer, the crawford won't help much (if any). But a MREV2 manifold would definately help.
Old Apr 25, 2007 | 01:05 PM
Jeff92se's Avatar
Red Card Crew
Actually if you look at the MD dyno sheets, their 5/16" spacer seemed to dyno the best overall. But the crawford came in a close 2nd.
In my search, I just ended up buying whatever decent spacer/plenum mod came up for sale soonest and at the best price. In my case, it was the crawford cast plenum. Not the tip top best in the dyno sheets but very close. And for the price it can't be beat.
I actually have one of their older plenums for sale
Old Apr 30, 2007 | 08:23 PM
timbo's Avatar
Bump!
Old Apr 30, 2007 | 08:41 PM
RebelinRI's Avatar
Crawfordz = 1/2 spacer. Stacking will do nothing but hurt you. Bump for a guy trying to sell something here!!!!!!
Old May 2, 2007 | 10:14 PM
filanj's Avatar
I haven't looked at them in a few months, but if I recollect correctly the competitors plenums that they used were outdated to the current models...
Old Nov 17, 2007 | 06:11 PM
Silver1's Avatar
A long shot--do you still have the Crawford? PM to 56560 if you do.
Raiderpolo15
18 Inch
11
Jan 30, 2017 03:25 AM
Raven7
Aug 14, 2015 04:40 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
realtalk21
Jul 20, 2015 09:07 AM
