I've had this installed on my car for aprx 9k miles... It was broken in correctly and the diff oil has been changed every 2k miles with Motul. The Diff is in like new condition, never tracked and all street miles.
NISMO LSD Info:
Designed as a multi-purpose LSD for city driving, this unit has increased power (slip resistance) for track or autocross conditions - Constructed with four pinion gears for improved strength over the stock setup of 2 pinion gears.
Specs:
• Clutch-Type Design with 10 clutches on each side
• Constructed with four pinion gears for improved strength (stock LSD has two pinion gears)
• 3-stage initial torque selective adjustable without disassembly
• Plate-type 1.5-way LSD can be converted to 2-way LSD
• Compatible on all 350Z & G35 Manual Transmission (with or without stock LSD)
• Compatible on 350Z & G35 Automatic Transmission when upgraded Final Drive gear is used (3.5, 3.7, 3.9)
Benefits:
• Designed as a multipurpose LSD for city driving
• Increased power for track or autocross conditions
Includes the following
• NISMO LSD
• 2 x Output Shafts
• 2 x Differential Side Oil Seals (recommend replacing with new ones from Dealership)
• 2 x Differential Side Bearings (recommend replacing with new ones from Dealership)
• Differential Bolts
$700 (Plus shipping and 3% Paypal)
NISMO LSD Info:
Specs:
Benefits:
• NISMO LSD
• 2 x Output Shafts
Will this LSD fit a sedan 6mt?
if i bought it what do i need? is it a straigh swap??? Is it sold yet very instrested
