FS SOCAL - OEM Z susp. + Dunlop tires
Old Jun 20, 2007 | 03:17 AM
dahkyne's Avatar
Someone buy my parts! Need room in garage!
---OEM Z susp. - UNrevised springs + UNrevised shocks; fronts completely assembled with top mounts ready to install, rears need top mounts from existing shocks; front and rear sways included; used 15k miles - $100
----OEM Z Revised Springs F + R - $50
---1 pair (2) Dunlop Direzza 245/40/18; about 75 miles on tires - $200
Take ALL listed for $250
PM or call 310-906-6965 - ask for Dexter
WILL NOT SHIP - WILL NOT SHIP - WILL NOT SHIP
Old Jun 21, 2007 | 03:18 AM
dahkyne's Avatar
bump... PM's replied
Old Jun 21, 2007 | 04:54 PM
richiesays's Avatar
whats the advantages of going w/ a Z setup? stiffer? whats ride comfort?
Old Jun 21, 2007 | 06:53 PM
dahkyne's Avatar
sedan guys (like me) usually run OEM Z suspension - it lowers the car an inch, stiffens the ride a bit (similar to OEM sedan sport setup), all without excessive camber and aftermarket parts cost. it works great for a mild drop and imrpoved looks.
coupes would only lower 0.5 in.- which in most cases is not enough
i've gone with full aftermarket Z susp. on my sedan recently - tokico d-spec shocks for Zs and eibach springs for Zs... so i need to rid myself of these OEM parts
Old Jun 21, 2007 | 10:58 PM
FamousG's Avatar
What's the difference between revised & unrevised? Are the Z's springs lower than the Sport G's?
Old Jun 21, 2007 | 11:10 PM
dahkyne's Avatar
Yes - OEM Z springs are shorter than OEM G springs; they are also stiffer and thus are not recommended to be used on a car that does NOT already have sport suspension
this should also help: https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
revised Z springs have stiffer rear spring rates; unrevised have the same rear spring rates as the G sedan's sport susp. package
Old Jun 22, 2007 | 05:52 PM
dahkyne's Avatar
bump
Old Jun 25, 2007 | 10:54 AM
hksjza70's Avatar
I'm half tempted to pick this up from you just so I don't have to roll 4x4 style on OE sport suspension . . .
Old Jun 25, 2007 | 10:59 AM
dahkyne's Avatar
since you literally live down the street from me, we can work out something as far as cost goes... let me know
Old Jun 25, 2007 | 11:39 AM
hksjza70's Avatar
are you sure you don't want the exhaust/y-pipe?
Old Jun 25, 2007 | 11:45 AM
dahkyne's Avatar
nah... i was seriously thinking about it after seeing it on the car, but i'm not gonna screw with that stuff right now.
i still have tires to buy
Old Jun 26, 2007 | 03:14 PM
dahkyne's Avatar
superbump
Old Jun 26, 2007 | 09:03 PM
g35ATX's Avatar
Originally Posted by dahkyne
superbump
LMK if you change your mind in shipping the OEM Z susp. I don't need the sway bars.
Old Jun 28, 2007 | 01:22 AM
dahkyne's Avatar
bump in the night...
Old Jun 29, 2007 | 05:40 AM
G35ster's Avatar
still available?
If it is, I'll come pick it up this weekend.
