G35/350Z aftermarket coilover, springs and shocks spec's w/updates
Rating: Thread Rating: 21 votes, 5.00 average.
Old Aug 26, 2005 | 12:09 AM
Gsedan35's Avatar
Just posting this to provide information for more informed choices.
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2008 (revised suspension)
Front:314 Rear:427
Nismo Z (2007-2008) ride height is the same as other Z models linear front, progressive rear (initial and final rates shown)
492/336-672
Eibach 350Z progressive springs 1”/1” drop* on 350Z G35 drops will be higher
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach G35 Coupe progressive springs 1.1”/1” drop on G35 coupe
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
Eibach G35 Sedan 1.1”/1.1” drop on sedan
Spring rates in LBS initial/final front 259/334 initial/final rear 359/416
Side Note: The sedan Eibachs were developed on a non sport sedan, they did not use a sport suspended car to do the R&D work.
Eibach 350Z sportline progressive springs 1.2"/1.2" drop G35 drops will be higher
F: 239/400 R: 257/435
Eibach G35 Sedan sportline progressive springs 1.6"/1.6" drop
F: 171/400 R: 285-502
RSR 350Z linear springs .6”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 345/417
RSR G35 coupe progressive springs 1”/1” G35 coupe drop
Spring rates in LBS 315/315
Beware, a 1" drop spring with NO increase in stiffness vs oem.
Hotchkis 350Z Linear springs .6”/.8” drop on 350Z G35 drops will be higher
Spring rates in lbs 340/330
Cobb Tuning 350Z Linear springs .75"/.9" drop G35 drops will be higher
Spring rates 436/535 (as shown here https://g35driver.com/forums/brakes-...new-parts.html )
UPDATE 7/18/11: Cobb discontinued this spring some time ago, some resellers might still have a set or you might have to make a wanted to buy thread to find a set.
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Tein H-tech G35 (fronts are progressive, rears are linear) coupe drop .6"/.3" sedan drop 1.4"/.7"
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Tein S-tech G35(fronts are progressive, rears are linear) coupe drop 1.2"/.9" sedan drop 2"/1.3"
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
G35 - DSK509 - 240f/300r - Linear Springs
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5" (2"/2.5" drop if installed on a G35 sedan. 1.5"/2" if installed on a G35 coupe)
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 314/353
Beware, a 1.2" drop spring is no increase in stiffness vs oem, G35 users have it even worse since your oem shocks are 3/4" taller vs oem Z shocks.
Tanabe NF210 Springs G35 COUPE progressive springs 1”/,6” drop on G35 coupe G35 sedan drop will be higher
Spring rates in LBS 297/336
Beware, a 1" drop on springs that are softer then oem springs.
Tanabe DF210 G35 COUPE progressive springs 1.7”/1.3” drop on G35 coupe, G35 sedan drop will be higher
Spring rates in LBS 308 /353
Beware, a 1.7" drop in the front on a spring that is softer then oem
Tanabe NF210 G35 SEDAN progressive springs 1.6”/.9” drop on G35 sedan
Spring rates in LBS 297/269
Beware, a large drop on springs that are softer then oem.
Tanabe DF210 G35 SEDAN progressive springs 1.7”/1.5” drop on G35 sedan
Spring rates in LBS 286/280
Swift 350Z linear springs .8”/.6” drop on 350Z, G35 drop will be higher)
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2"/1"
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Swift G35 coupe linear springs 1”/.6” drop on G coupe, G35 sedan drop will be higher)
Spring rates in LBS 280/314 (softer then oem)
Beware, spring rates are softer then oem.
Nismo T2 350Z Linear springs 1”/1” drop on 350Z
DO NOT RUN THESE WITH OEM SHOCKS OF ANY KIND! TCKline DA's were specifically designed for these springs, however I'd pony up for AST4100's or Anze Engineering Penskes
Listed for information ONLY!
Spring rates in LBS 690/690
Vogtland 350z progressive springs 1”/1” drop on 350Z G35 drop will be higher
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Kg/mm springs 350Z
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm springs 350Z
DRacing 30mm drop
Spring rates in LBS initial/final front 252/454 initial/final 252/482 rear
Espelir G35 coupe progressive springs .4"/.4" drop
Spring rates 409/515 (rear rate IMO is too high for all oem shocks, Z or G)
Espelir 350Z progressive springs .4"/.4" drop (G35 drops higher)
Spring rates 386/515 (rear rate IMO is too high for all oem shocks, Z or G)
H&R sport springs G35 coupe (progressive springs)
1.1"/1" drop
no spring rate info H&R refuses to give it out, something that is critical to making a informed buying decision, buyer beware)
H&R sport springs G35 sedan (progressive springs)
1.3"/1.2"
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Skunk2 350Z progressive springs 1.3”/1”
Spring rate in LBS 238/381 237/395
Skunk2 G35 coupe
Same specs as 350Z, which is strange because normally G35 spec springs have different spring rates and generally a slightly different drop
Tein Flex (twin tube construction, adjustable dampners
Full-length adjustment and height adjustment for separate setting of the height and spring preload
Spring rates 672/672
Side Note: High spring rates mean even when the adjustable damping is set as low as possible, you may not find ride quality happiness, several reports of this setups harshness exist Yet a few owner comment’s of a “like stock ride quality” also exist. However given the fact that they use a spring stiffness that’s over 100% stiffer then oem, if ride quality is of concern, either hitch a ride in a car equipped with them or make a different choice. In addition, several review’s have been done by people actually having the original more softly sprung Tein Flex coilovers do not take their comments to mean the same as the one using the current product, the original product specs are listed below under Tein Flex JDM.
Tein Flex JDM specs (can be special ordered est 10-12 weeks delivery)
Spring rates 560/560
side Note: This is the original specs first offered in the U.S. with the Flex, shortly after it’s introduction the specs changed to those listed further above (672/672)
Tein MonoFlex Monotube, adjustable dampning M.S.V valving, full height adjustable
Spring rates 784/784
Side Note: Well reviewed on my350Z, but a greater level of caution should be exercised if you drive on "B" roads very often. Also, not a slam dunk vs other offerings in the same class.
Tein MonoFlex JDM same specs as above, but softer valving and spring rates
Spring rates 560/504
Tein Super Racing Monotube, external reservoir, adjustable with independent settings for compression and rebound, full height adjustable
Spring rates 895/895 (web site say's they don't come with springs)
Side note: Questionable valving, lack of overall resources, having one source to repair, and having several other choices in this class make this a tuff sell.
Tein Basic (twin tube construction, non adjustable dampners )
Spring rates 504/504
Side Note: Popular because of price and the brand name. Some say it has too much bounce, others like the setup just fine. Getting a ride in a owner equipped car before you buy, isn't a bad idea.
Tein SS JDM (twin tube construction, adjustable dampners )
(JDM only at this time. 10-12 weeks delivery, come via ship)
Spring rates 392/392
Shock dyno's can be seen here. http://www.tein.co.jp/techinfo/techi...4/00118_8p.htm
Tein CS (Monotube constructionad, adjustable dampners )
Special Note: They are valved and sprung to fulfill their intended mission of offering up improved ride comfort. More specifically their valving will impact the performance they can deliver. If you want performance, pick a different Tein offering or pick a different brand.
Old Aug 26, 2005 | 12:12 AM
Gsedan35's Avatar
Nismo S-tune shock and spring setup 350Z (twin tube, fixed height)
.6"/.6" drop (as shown on page 10 http://www.nissanusa.com/pdf/microsi...ar_catalog.pdf )
Spring rates 393*-448/254*-504
*estimated initial spring rates (notice the front doesn’t have much spread)
Nismo S-tune shock and spring setup G35 coupe twin tube, fixed height
.8"/.8"
448/504 (front spring slighly progressive, rear progressive
Nismo S-tune G35 sedan twin tube, fixed height
1"/1" drop
Spring rates 347/342 (progressive springs)
Ohlins PVC coilovers Monotube, adjustable damping (listed on many web sites as rebound only, this in not correct) Full height adjustablity on the fronts
Spring rates 560/392
Side note: PVC vavling system operates on compression side to improve control and still offer comfortable ride. Good compromise between spring rate and ride quality. I now own these
Standard ride height on 350Z -.8"/-8"
Min drop amount on 350Z Front: -2" Rear:-.2"
Max drop amount on 350Z Front:-1.4" Rear -1.4"
http://www.carrozzeriajapan.co.jp/ohlins/4w/pcv.html
^use this to translate http://babelfish.yahoo.com/
Ohline DFV coilovers
Same specs as PVC above, but valving system also works on rebound, damper bodies are aluminum vs steel.
Jic Flta-2 350Z Z33FLTA2H
(Monotube construction, adjustable dampning)
Special Note: This setup is known for it’s extremely harsh ride quality, buyer beware get a ride and drive in a Z33 spec setup before you buy. Add in Jic's extreamly poor customer service in the U.S., pick a different system.
Spring rates560/672
Note: We have seen this setup run with softer 504lbs rear springs , search post’s by FritzMan on my350z
Jic Flta-2 350Z Z33FLTA2S****
same as above but with softer progressive rear springs.
560/560.
Jic Flta-2 G35 coupe CPV35FLTA2
(Monotube, adjustable dampning)
Spec change!
I have no idea when this happened, but the Jic-Magic web site now show's the spring rates as 560/448
Jic Flta-2 G35 sedan (Monotube, adjustable dampning)
As of 1/06/07, this coilover is no longer listed on Jic's web site
Spring rates 504/392
FLT-A2-VIP Series
The new FLT-A2 VIP are made for the enthusiast that wants that extreme dropped look and high quality ride comfort. Shares many performance features as the FLT-A2's but made specifically for high end luxury vehicles.
G35 Sedan
Spring rates 504/336
FLT-A1 350Z, Twin tube construction, 10 way adjustable, full height adjustable
Spring rates 560/560 Z33FLTA1**** (rear springs are progressive)
G35 Coupe, Twin tube construction, 10 way adjustable, full height adjustable
Spring rates 560/448
G35 Sedan, Twin tube construction, 10 way adjustable, full height adjustable
Cusco Zero 1&2 Full-length adjustment and height adjustment for separate setting of the height and spring preload
Zero 1 has non adjustable dampning
Zero 2 has adjustable dampning
Side note: One of the better setups on the market, worth $600 more vs other choices in the $1000 price range.
Bilstein PSS coil over Monotube construction, non adjustable dampners, reuses oem upper shock mounts
Spring rates 370/240-420 (rear progressive)
Note: A superior choice for ride quality vs Tein basic, Eibach Pro-S and Kw Variant 1, with better valving and lower sprign rates Likely a better choice vs Tein CS too. If your considering having them revalved, use Bilstein and no one else!
Bilstein PSS9 coilover Monotube construction, adjustable dampners, reuses oem upper shock mounts
Special Note: If you keep the damper adjustment at or below 5, this setup delivers a ride and drive quality that is beyond reproach. Settings above 5 are not advised, ride and performance is compromised, I used to own these.
Bilstein Pss10
Same as the Pss9, however it add's on more level of damping adjustment and it does feature different valving, spring specs are unchanged.
HKS III (not the Sport model) Monotube, adjustable damping*, full height adjustablity Replaces the HKS RS *Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 448/448
Side note: Like a lot of products that promise street comfort and trackability, this setup may or may not delivery on the track. Review's to date do suggest they deliver on the comfort promise however. Yet, IMO it is one of the better choices and worth a premium vs several $1000 choices.
HKS III Sport (Monotube adjustable damping*, full height adjustablity Replaces the HKS II. *Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 616/672
Side note: Valved rather stiffly according to the specs listed at HKS Japan
HKS LS+ G35 Coupe Monotube construction, adjustable dampners Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 504/448 ( out of production, no longer avaliable )
Side Note: Has the unusual distiction of actually being valved stiffer then the same coilover made for the 350Z (though you can only see 350Z LS+’s in the JDM catalog).
HKS LS+ 350Z Monotube construction, adjustable dampners Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 448/448 ( out of production, no longer avaliable )
Sidenote: Listed on HKS's Japan web site, but not on the US web site. These might actually be our RS coilover.
HKS LS G35 (Monotube construction, non adjustable dampners)
Spring rates 448/336 ( out of production, no longer avaliable )
Special Note: A comfort ride system, compare to Tein CS coilover
HKS LS 350z (Monotube construction, non adjustable dampners)
Special Note: A comfort ride system, note higher rear spring rate vs. G35 application
HKS II Monotube construction, adjustable dampners Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 504/504 ( out of production, no longer avaliable )
Special Note: sprung and valved to be HKS’s most aggressive product for the G35/350Z, it is a notch above the RS coil over on the track, compare to Tein Flex and Jic coilovers. May be very tuff to get, said to have been removed from the USDM HKS catalog and is now JDM only, or so I’ve heard.
HKS RS Monotube construction, adjustable dampning Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Special Note: “Marketed” as HKS’s track coil over with a good street ride.
$1600 when on sale Owner review's have been extreamly positive since it's introduction.
Old Aug 26, 2005 | 12:13 AM
Gsedan35's Avatar
Stance LX+Pro Twin tube, adjustable damping, ride quality system*
Spring rates: 616/560"
Notes:*Sold as having a "luxurious ride quality" because of it's twin tube contruction. However, you can have the best dampers on the face of the earth, but it won't matter with springs as stiff as this setup uses. If your after ride quality, buy HKS III, Bilstein PSS10, or Tein CS.
Stance GR+ Monotube, adjustable damping, full height adjustablity
Spring rate true coilover* version 672/280* (*='s about a 672 spring in the oem rear location)
Spring rate oem style rear 672/616
Side note: Well liked on my350Z, most popular with the "drop it to the ground" crowd, several have been pulled and resold because they did not deliver on the track, not suprising better choices exist that are worth paying more for.
Stance GR+Pro
Same specs as GR+ true coilover, but add's a helper springs in the rear.
Not worth paying extra for given what helper springs are for and what Stance suggests you are to use helper springs for.
Stance GR+Pro 3-way Twin tube construction, true coilover, full height adjustablity
Top of dampers adjusts rebound only, 15 settings. Seperate gas canister has 15 adjustments for low speed compression (piston speed) and 4 adjustments for high speed compression (piston speed)
Stance GR+ Pro SS-D, AL-Pro
Same specs at GR+Pro, but with special valving for track use.
Side note: Don't get confused, these are not Penske, Ohlins, Moton, Zeal, JRZ or Koni. All these companies can lay claim to racking up win's, does not mean squat, lot's of people podium on rather crappy shocks. Their is a reason the top companies delivery, construction and valving. Buy NOTHING in this class before seeing a real shock dyno, standard and one with a hysteresis loop.
Zeal Function Xs Monotube, adjustable dampning(6 levels), full height adjustablity
Generally stocked as a truecoilover setup in the rear and avaliable by special order with a oem style sperate spring/dampner setup in the rear
Side note: If you special order them with different spring rates, Zeal automatically changes the valving to suit your rate choice. Understood as a top 5 product, yet little to no information exists to back this up.
Zeal Function X Monotube, adjustable dampning (30 levels), full height adjustablity.
Spring rates 672/560
KW coilovers Variant's 1,2&3
twintube construction, uses Oem upper shocks mounts
V1=non adjustable dampning,
V2=adjustable damping,
V3=separate adjustability for compression damping AND rebound damping
Spring rates Front 485lbs to 525Lbs Rear: 240Lbs to 548Lbs (progressive springs)
Side note: Covering a wide range, these three products offer up german engineering. I have shock dyno's of the Variant 2, they look pretty good. All three version's use a progressive rear spring with a wide rate spread, which will compromise aggressive street and track driving, though this can be fixed.
Eibach Pro street S coilovers
Drop range on 350Z 0.8 to 1.6" front same for the rear.
As per Eibach they are relabled KW variant 1 coilovers, springs are a different color simply because Eibach has them refinished red vs yellow.
Greddy Type S coilovers
Monotube, 32 way adjustable, full height adjustment
350Z and G35 coupe fitments have different part numbers and different spring free lengths
Note: Likely OEM supplied by Bc Racing
D2 Racing/Ksport Coilovers
Monotube constrution full length height adjustment separate from preload rear springs on coilover bodies
side note: Buy something else, given all your other choices, not worth your time,
Kg/mm DNA coilovers (this setup uses 4 springs on the rear of the car)
(Monotube construction, full length height adjustment separate from preload, adjustable dampners)
Spring rates in LBS Front 748 Rear progressive 336 to 672 + 280 linear on dampner
Stiffer then oem springs by F+238% R+233% to 331%
Buddy Club Racing spec coilovers (rear springs on dampners ONLY)
Spring rates in LBS Front 560 Rear 448*
Stiffer then oem by F +78% R +113%* (see note at very top)
With 336lbs rear springs R +64%*
R-SR I-shock coilovers (JDM only, R-SR USA may or may not be able to get them ) ride height 0mm to -30 mm on 350Z looking at pics, looks like they have full length height adjustment separate from preload with 46mm piston’s pretty sure they are monotubes Uses titanium springs (Ti2000)
http://www.rs-r.co.jp/products/shock/sports.htm
http://www.rs-r.co.jp/products/shock/pdf/z.pdf
Spring rates in LBS 560/504lbs
Silk Road SPEC-RM/A8 coilovers monotube 8 way adjustable dampners, full length height adjustment separate from preload
Spring rates in LBS 560/448
http://www.silkroad-jp.com/section/a8.html
$1699
Unitech racing/Truechoice Koni coilovers Shortned and revalved Koni shocks converted into coilovers, extensive R&D by the PerformanceNissan racing team, Unitech
Phase 3 have adjustable shocks Phase 4 are DA independent for bump/rebound
Spring rates in LBS 500/425
Side note: Very specific valving with a compression curve that is more digressive then competive dampers from TcKline. Vs the TcKline damper, they also have much better internal pressure balances, for much lower hysteresis level.
Moton Club sport dampners with threaded shock bodies, monotube contruction, seperate gas canisters, double adjustable with independent adjustment for rebound and compression.
Spring rates: springs sold seperately, call manufactuer
Shocks
Tokico D-spec twin tube 8 way double adjustable (bump and rebound) gas shocks 2 fitment's are sold DSP-7 for the G35 and DSP-9 for the 350Z.
The only difference between the DSP-7 and 9 is that the rear shocks on the DSP-9 350Z fitment feature's shocks that have shorter bodies by 3/8" and piston shafts that are 1 7/8" shorter The 2 fitment's are both valved the same. These shocks can be set from softer then oem G35 shock to stiffer then the oem 350Z shock, your choice depending on how you set them.
$489
Side note: Do not run them with any spring that is beyond 450lbs, cannot be revalved, serviced by Tokico USA only.
Koni Sport SA twin tube shocks Single adjustable for rebound.
Side note: IMO, do not run spring rates above 450lbs in the front and 450lbs in the rear, without having them revalved. Can be serviced, revalved, shortened, even converted to double independent adjustablity for seperate rebound and compression control by several authorized Koni service providers. I have shock dyno's for them.
$750-$950+
Bilstein H.D. Monotube, non adjustable
The best shock out at a respectable price, provided your not asking it to run with springs that are too much stiffer then oem. Can be revalved by Bilstein USA for only $65 per shock
JRZ twintube DA shocks
$3500+
May or maynot have been a one off custom shock, call JRZ
sidenote: Do not let the twin tube construction fool you, this likely have the R&D power applied to overcome that design, much as Ohlins Twin tube for other apps would also.
TcKline Racing DA shocks $419 each
These shocks are a double adjustable version of regular Koni SA shocks custom made for Tckline by Koni. They seperate adjustability for compression and rebound dampning via to seperate adjustment systems. They have their own valving specs totally seperate from Koni SA valving. They have a second spring perch grove cut on the front shocks that is 1" lower vs the front Koni SA shock that has a second grove cut 1/2" higher. Can handle up to 800lbs spring rates. Just like Koni SA shocks, these are a low pressure twin tube design.
http://www.tcklineracing.com/nonbmw.htm
Update note: I have shock dyno's on the TcKline shocks, after reviewing them myself and speaking with the shop that did the dyno, spend your money on something else.
Koni Race 2812 series
Mono tube shocks, double adjustable for rebound and compression seperately, front shocks have threaded bodies for height adjustment, Race-Valved Custom Damper Option, Limited Street Use, No Warranty, Lead Time approx 4wks. $3980 Retail Read pages 5 and 6 detailed infohttp://www.koni-na.com/pdfcatalogs/KONIMotosportCatalog.pdf
Penske coilovers (monotube construction, your choice of single adjustable, double, even trible adjustble.
http://anze.biz/applications.cfm
Side note: Not cheap, but penske makes some of the best dampers you can buy,....period. If you invest in the parts, you can revalve these yourself, training classes are even offered. And that's the other side of things, Penske makes a wide selection of parts for different valving setups.
Old Aug 26, 2005 | 12:35 AM
ipse dixit's Avatar
Sticky.
Old Aug 26, 2005 | 01:49 AM
dklau33's Avatar
Agreed. Great info Jim.
Old Aug 26, 2005 | 02:03 AM
achen's Avatar
wow.. awesome post. very helpful.
Old Aug 26, 2005 | 02:27 AM
xswl0931's Avatar
I'm interested in the Zeal's due to the reputation of the company and the glowing reviews. However, doesn't the transfer of stiffness to the front mean even more understeer? Wouldn't I want to find a combination that transferred some stiffness to the rear to make the car more neutral? Thanks.
Old Aug 26, 2005 | 07:47 AM
kenchan's Avatar
Gsedan35- you did it again. nice job.
Old Aug 26, 2005 | 08:13 AM
Endless G's Avatar
+1 Sticky :O
Old Aug 26, 2005 | 08:53 AM
Cactus's Avatar
Originally Posted by Endless G
+1 Sticky :O
+2 Awesome post thank you!!!
Old Aug 26, 2005 | 09:02 AM
robbdogg's Avatar
thanks!
Old Aug 26, 2005 | 01:14 PM
vodkarocket's Avatar
Modded Member
Wow, there is a plethora of information in this thread- definitely worthy of a sticky!
Old Aug 26, 2005 | 03:51 PM
dklau33's Avatar
If the mods aren't going to sticky this I suggest everyone copy and paste the info to a word doc or a text file. This is the most complete list I've seen yet.
Old Aug 27, 2005 | 12:55 AM
rocka_fellow's Avatar
thank you very much Jim
Old Aug 27, 2005 | 01:07 AM
GEE PASTA's Avatar
Florida G35 Club
I find this information very accurate, Sticky!!! Sticky!!!
Wow great write up. Your the man!! Thanks!
You have already rated this thread Rating: Thread Rating: 21 votes, 5.00 average.
