Streetwires Zeronoise 3 - RCA's
Old Jul 22, 2007 | 08:02 PM
silvernole12's Avatar
I have a 6.5ft and a 11.5ft RCA cable that was pulled out of my older install. These use twisted pair conductors for noise rejection.
They were used for only about 1 yr. The 11.5 ft cable has one end where I cut off the RCA plugs so you will need to buy some new ones to attach back on or use it to splice it off the signal from the factory HU. The 6.5 ft one is complete and intact.
Here is some info on them
Silver-Plated Oxygen Free Copper: These cables use Silver-Plated Oxygen Free Copper for maximum conductivity with minimal cross-section.
Hyper Twist: The Hyper Twist twisted pair design passes all the music with none of the noise.
Crystal-flex Jacket: The outer jacket is a clear Crystal-flex material for easier cable routing.
Color-coded: Color-coded bands are used for easy left and right identification.
Six Cut Machined Connector: The connector has six cuts to stay firmly attached to the component.
Sure Grip Machined Body: The body of the connector has a low profile to fit in tight spaces and allow for easy gripping.
Split Pin: The RCA pin is split for solid contact.
Both wires for $20 plus shipping
JustinMKN1
Sep 18, 2015 03:40 PM
tgenius
Apr 9, 2005 02:23 AM
smokeator
Mar 4, 2005 12:28 AM
aorbeta
Jun 8, 2004 04:19 PM
Eurog35
Apr 20, 2004 08:24 PM
