VIP puddle lights
Old Aug 16, 2007 | 01:58 PM
Steel Blue's Avatar
I want to see/know how hard it is to wire so that it is clean looking.
Do we need to take apart door panels, etc etc
Old Aug 24, 2007 | 04:02 PM
SilviaVsSupra's Avatar
these can be used to look really classy.. or really ricer! if you take the time to install these right, you will probably have to remove the door panel, or mount a switch or something of the sort depending on how you want them to work.. i would wire them to the dome lights so.. ON with the open door, and OFF when the door is closed.. just like the new Lexus'
Old Aug 24, 2007 | 04:12 PM
g35man04's Avatar
CLUB MODERATOR
I am wiring 3 to the door panel dome light on each side and installing the lights on the bottom side of the side skirts and then putting 2 under the bottom side of the hood so with hood popped at night car shows the engine is flashy! I will post pics once the install is complete!
Old Aug 27, 2007 | 10:41 AM
Steel Blue's Avatar
any pics yet?
Old Aug 27, 2007 | 11:06 AM
g35man04's Avatar
CLUB MODERATOR
not yet....still working on how to wire them on the hood to keep a clean look.....I am wondering also when i wire them underneath there if they will get to hott and melt.
Old Aug 27, 2007 | 03:35 PM
_evilMonkey_'s Avatar
i'll take one or two, pm me with paypal info. thanks
Old Aug 28, 2007 | 06:16 PM
if you keep the lights towards the rear of the hood, such as over the battery and MS they wont get hot at all.. if you have your engine cover on still i doubt it would get hot enough sitting right above them.. it would be hot to see some light come from underneath as well! entire engine would be lit
Old Aug 28, 2007 | 06:21 PM
g35man04's Avatar
CLUB MODERATOR
well i may try to wire them to the clear corner lights....that run at night time...see if i can light up th engine!!
Old Aug 29, 2007 | 12:50 AM
no point in having them on when your hood is closed though.. switch is much more practical
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Jnm07
Sep 5, 2015 01:16 AM
