Fs: Work Varianza T1s 9.5/11 Crystal Silver Wheels
Old Sep 10, 2007 | 06:52 PM
  #46
richiesays's Avatar
Originally Posted by joshlee
still have these richie? if so i think i might want them
still available!
Old Sep 10, 2007 | 06:53 PM
  #47
richiesays's Avatar
Originally Posted by jdmgee35
Do the fenders need any modifications? I noticed the offsets are super aggressive. Thx.
i had my fenders cut when i was running with the sf-challenge and 295 tires.
Old Sep 10, 2007 | 09:26 PM
  #48
soysauce21's Avatar
bump for some nice wheels! seen them in person
btw give me my camera rich
Old Sep 10, 2007 | 11:00 PM
  #49
l2ed Skyline's Avatar
PM'd You.. Really like to pick these up this weekend...
Old Sep 11, 2007 | 02:51 PM
  #50
richiesays's Avatar
wheels pending...
Old Sep 11, 2007 | 03:00 PM
  #51
SFLG35's Avatar
FGC President
those are not aggressive offsets, but im sure he had fender modification done
wheels look good. good luck with the sale.
Old Sep 11, 2007 | 03:38 PM
  #52
richiesays's Avatar
11" w/ a R disk +22 is comparable to 10.5" +18-17 so that is semi aggressive.
Old Sep 11, 2007 | 04:15 PM
  #53
SFLG35's Avatar
FGC President
ok ill give you that.
i cant wait for my sc1's to get here. i got 20 11 +10 O disk in the rear and 20 9.5 +10 A disk in the front.
can you explain the difference in the disks to me? i was told that O disk will give you the biggest lip, and the A disk will allow for clearing of a bbk in the front.
sorry fo hijack your thread. if you dont want to explain here hit me up on AIM or PM thanks
Old Sep 11, 2007 | 10:26 PM
  #54
richiesays's Avatar
Disk represents the thickness of the mounting pad of the wheel. The mounting pad is the center part of the wheel where it attaches to the hub of your car, and where the lug nuts go into. The thicker the mounting pad/higher the disk, the further the spokes are pushed outwards, away from stuff like big brake calipers. And the thinner the mounting pad/lower the disk, the further in the spokes are. So imagine that you have two wheels of the same width, and same offset, placing the face of the mounting pad where it contacts the hub in the same location. The wheel with the higher disk has a thicker pad, which moves the spokes outwards, which in turn, means that there is less lip than the same width, same offset wheel in a lower disk.
An A disk (higher disk to clear the brake caliper) in front, and the O disk (lower disk that you can run because of rear drums) in back, the rear, even though it is the same width and offset, will have right around 10mm more lip.
Old Sep 12, 2007 | 01:38 AM
  #55
SxExCx's Avatar
Richie..u r retarded! Make up your freakin' mind!!!!! LOL
I think these wheels are keepers!
Old Sep 12, 2007 | 12:38 PM
  #56
Consider These Sold To Me!!! Dibs
Old Sep 15, 2007 | 04:29 PM
  #57
richiesays's Avatar
LA County Fair Time! =\
bump... still available!
Old Sep 16, 2007 | 05:30 PM
  #58
richiesays's Avatar
bump
Old Sep 16, 2007 | 06:03 PM
  #59
richiesays's Avatar
new pictures!
Old Sep 18, 2007 | 02:35 PM
  #60
richiesays's Avatar
bump
