Fs: Sony And Jl Audio Amps
Old Sep 7, 2007 | 10:22 PM
g35man04's Avatar
CLUB MODERATOR
LIke the title says i am considering on selling these so i can upgrade to just one amp on my car.....They are in basically brand new condition. I havent had them for a while.
JL AUDIO e1400D Class D Monoblock Amplifier...
PRICE: 180.00 shipped
Actual pic is at bottom of post. I will add more this evening.
Specs:
Product Description:
Class D Monoblock Full Range Amplifier
High-Damping Class D Circuit with discrete contorl circuitry
Pass-through RCA outputs
On-board crossover: Variable Low-Pass Filter: 20 -200Hz, Selectable Slope
High level inputs
CEA-2006 Compliant
RMS Power Rating (14.4V):
4 ohms: 320 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
RMS Power Rating (12.5V):
4 ohms: 200 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
Frequency Response: 10 - 250Hz
Damping Factor: >500 @ 4 Ohms / 50Hz, <250 at 2 Ohms/50Hz
Input Range: 200mV - 8V RMS
Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
Dimensions: 11.81" L x 9.25" W x 2.36" H
JL AUDIO e2150 2-Channel Car Amplifier Amp
PRICE: 100 shipped
Specs:
2-Channel Class AB Amplifier
Absolute Symmetry Class AB Circuit
Differential, Noise-Cancelling Input Topology
RMS Power Rating:
14.4V
70 watts x 2 chan. @ 4 ohms
110 watts x 2 chan. @ 2 ohms
140 watts x 1 chan. @ 8 ohms (Bridged)
220 watts x 1 chan. @ 4 ohms (Bridged)
12.5V
45 watts x 2 chan. @ 4 ohms
75 watts x 2 chan. @ 2 ohms
90 watts x 1 chan. @ 8 ohms (Bridged)
150 watts x 1 chan. @ 4 ohms (Bridged)
Low and High-Level Inputs
Preamp outputs: 1 Pair
Power and Protection LEDs
Remote Bass Control Port (Controller RBC-1 optional and not included.)
Bass EQ: 6dB @ 48 Hz
Adjustable Input Sensitivity
Built-In Crossover: High/Low Pass 50 - 100 Hz
Power connectors: 8 - 4 AWG
Speaker Connection: 8 - 16 AWG
Dimensions: 9.8" L x 9.25" W x 2.36" H
SONY XPLOD XM-2002GTR 1,200 WATT 2/1 CHANNEL CAR AMPLIFIER
PRICE: 80 shipped
Specs:
Features
1200 W peak output
two channel bridgeable car amplifier
built-in cooling ventilation (keeps your amp cool at all times and makes sure it does not overheat)
200 watts RMS x 2 @ 4 ohms
250 watts RMS x 2 @ 2 ohms
500 watts RMS x 1 bridged @ 4 ohms
high level sensing power on the circuitry
variable low-pass filter (50-300 Hz at 12 dB per octave)
bass boost (10 dB @ 40 Hz)
Class A/B 2 channel bridgeable car amp
Tri-way capable
MOS-FET output stage and power supply
C--E--A-2006 compliant
preamp- and speaker-level inputs
preamp outputs
15-7/8"W x 2-1/4"H x 10 7/8" D
Signal to noise ratio (dB): 100
Frequency Response (Hz): 5 - 50k
Input Level Range (V) Line level input: 0.3 - 6
Input Level Range (V) Speaker level input: 1.2 - 12
Operating Voltage (V): 10.5 - 16
built and high level inputs to install your amplifier to a factory stereo
built-in bass boost control
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
