FS: Kicker Square Subwoofers, Kicker Amplifiers, Kicker 6.5" Components
Old May 5, 2008 | 02:13 AM
kingrukus's Avatar
LIKE NEW Kicker 06DS12L52 Vented enclosure with dual 12" Kicker L5 Solobaric subwoofers
This subwoofer system was used for 2 weeks and is in excellent condition, basically like new. It hits very hard, and is built very well, with two 12" Kicker L5 Solobaric subwoofers in a well crafted Kicker built-to-spec vented enclosure.
  • like NEW, IN EXCELLENT CONDITION!!!
  • Dual 12" Vented Sub Enclosure Loaded with 2 Solo-Baric 12" L5 Subwoofers
  • 3/4" medium density fiberboard construction covered with gray and black carpet
  • 2-ohm total impedance
  • power handling: 2400 watts MAX/1200 watts RMS
  • Embroidered Kicker logo
  • Oversized port
  • Combo vent/terminal cup
  • Dimensions: 16-3/8"TD x 19-9/16"BD x 32-3/8"W x 16"H
Asking $500.00
Kicker ZX350.4 4 Channel Amplifier
If you're into great sound, you'll love Kicker's ZX series amplifiers. These high-end amps set the standard for powerful sound, with a distinctive look that'll make your installation stand apart from the crowd.
The built-in variable frequency filters adjust the amp's output to get the most out of your speaker setup, whether you're running full-range speakers or subs. Use the bass boost control to dial in the exact amount of low-end bump you're looking for.
  • 4-channel car amplifier
  • 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
  • 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
  • variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
  • variable bass boost (0-18 dB at 40 Hz)
  • top-mounted controls
  • speaker- and preamp-level inputs
  • fuse rating: 20A x 2
  • 13-1/2"W x 2-5/16"H x 9-5/8"D
Asking $265.00
Kicker ZX1000.1 1000W Mono Amplifier
Kicker's ZX series have been designed from the ground up to deliver tight, clean power. The ZX1000.1 efficient Class D circuitry allows the amplifier to really pour on the power in 2-ohm operation. All this power is at your command with a variable crossover, high- and low-level inputs, and defeatable subsonic filter to help protect your subs.
  • Class D mono subwoofer amplifier: Provides massive power to your subwoofer without drawing lots of power from your system.
  • RMS Power Output - 1000 watts @ 2 ohms, 500 watts @ 4 ohms
  • Peak Power Output - 2000 watts @ 2 ohms, 1000 watts @ 4 ohms
  • Protection circuitry: Protects against short circuits, overloads, heat and reverse polarity.
  • Expansion options: Speaker-level and RCA inputs make it easy to add on to your system.
  • Variable crossover: LP(50 - 200 Hz)
  • Signal-to-Noise Ratio: 95 dB
  • Speaker and preamp level inputs
  • Bass Boost: 0 - 18 dB
Asking $375.00
LIKE NEW - Kicker KS6.2 6-1/2" component speaker system
The Kicker KS6.2 component speaker system renders the low frequencies with light, yet rigid 6-1/2" woofers, suspended in vibration-dampening rubber surrounds. Sturdy steel baskets provide a solid housing with plenty of venting to keep internal parts cool.
Aluminum dome tweeters project the highs with authority, slicing through road noise to ensure lifelike stereo imaging. External 2-way crossovers provide a seamless transition between the woofers and tweeters — you'll revel in detailed, realistic sound when you play your favorite tracks.
The versatile KS6.2 system includes mounting hardware for a variety of tweeter mounting options, or you can install the tweeters inside the woofers to create high performance 2-way speakers.
  • Mid bass drivers used for 1 week, the rest of the items are BRAND NEW IN PACKAGE, NEVER USED!
  • component speaker system includes woofers, tweeters, and crossovers
  • 6-1/2" polygraphite woofer with Santoprene surround
  • 1" aluminum dome tweeter with multiple mounting options
  • tweeter may be mounted on woofer as a high-performance coaxial speaker
  • external 2-way crossover (4000 Hz, 12 dB/octave high-pass, 6 dB/octave low-pass)
  • marine ready with water-resistant mounting hardware
  • power range: 6-75 watts RMS (150 watts peak power)
  • frequency response: 35-21,000 Hz
  • sensitivity: 88 dB
  • top-mount depth: 1-15/16"
Asking $150.00
Local pickup in the GTA preferred (I am in the west end, Mississauga/Brampton area).
Please e-mail me at paradigm905@hotmail.com or PM me if interested.
Thanks
Old May 8, 2008 | 11:50 PM
kingrukus's Avatar
Kicker ZX1000.1 1000W Mono Amplifier Sold!
Rest of items are still available.
Old May 15, 2008 | 10:11 PM
kingrukus's Avatar
Kicker 06DS12L52 Vented enclosure with dual 12" Kicker L5 Solobaric subwoofers sold!
Old May 20, 2008 | 06:32 PM
kingrukus's Avatar
Kicker KS6.2 Component Speakers sold!
Kicker ZX350.4 4 Channel Amplifier available, price negociable
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
