FS: G37 OEM Big Brake Kit
Old May 13, 2008 | 10:38 AM
MaxToTheG's Avatar
Trying to get a Big Brake kit myself... gotta sale the Stock ones first...
This is the OEM G37 brakes. Akebono makes them.
Size:
14.0 x 1.3-inch ventilated discs, 4-piston opposed calipers (Fronts)
13.8 x 0.8-inch ventilated discs, 2-piston opposed calipers (Rears)
Sharif at Forged will be doing the install and taking care and getting the stock brakes off the car and handled with care...
This will include everything that is replaced from a aftermarket BBK.
The brakes are in perfect condition and the calipers have been cleaned alot.
My car has aroung 4,xxx miles on in.
If you local to ATL I can leave the brakes at Forged for you if you want.
Price: 1850 Shipped
This is a great way to upgrade your brakes and not spend $6,000-12,000 dollars on aftermarket.
I wanna get these moved so I can go ahead with my BBK.
PM me with questions...
I am a moderator over at Myg37.com so I am a credible seller.
Thanks
Old May 13, 2008 | 06:15 PM
OMEGA46's Avatar
isnt 14.0 BBK already?
any pics?
Old May 13, 2008 | 06:17 PM
OMEGA46's Avatar
Trade?
Old May 13, 2008 | 11:03 PM
MaxToTheG's Avatar
yes its big... goin for 15 inch...
Old May 14, 2008 | 01:32 AM
MaxToTheG's Avatar
all PMs replied...
Old May 14, 2008 | 01:37 AM
MaddG's Avatar
IF your in socal ...
Old May 14, 2008 | 10:26 AM
DG35Cpe's Avatar
So these will fit an 04 coupe? Any modifications needed?
Old May 14, 2008 | 04:50 PM
App6MT's Avatar
Littering and...
Sells for $1550 new from Riverside Infiniti. Not trying to be a dick at all, just putting it in perspective.
Old May 14, 2008 | 04:55 PM
J2S2M's Avatar
Ouch.
Old May 14, 2008 | 05:30 PM
lowrider's Avatar
Actually I just called them. They said $1800.00 for the complete kit.
Lou
Old May 14, 2008 | 07:13 PM
MaxToTheG's Avatar
your crazy... 2100+ from riverside... troll
Old May 14, 2008 | 07:15 PM
MaxToTheG's Avatar
Does no one read the vendors section here?
Riverside is all over it advirtising this kit for 2100+
Old May 14, 2008 | 07:17 PM
MaxToTheG's Avatar
For you all who cant navigate the forums and find things... see Riversides post below!
Originally Posted by Tony@RiversideInfiniti
Hello Everyone!
We have some exciting news for anyone with a V36 (07-up G Sedan).
We are now offering Big Brake Kits for you! These are the Factory Infiniti brakes from the G37 Sport Models. These kits will be all inclusive, down the nut and bolt that you need.
The perks:
These kits utilize 100% factory OEM Infiniti/Nissan parts, so you should have no issues with warranty as long as the install is performed correctly.
These utilize the big Akebono 4-piston front, 2-piston rear calipers from the G37 as well as the larger 14"/13" rotors. Everything is included, which means all dust shields, e-brake components, brackets, lines, all hardware, MOTUL RBF 600 Brake Fluid, rotors, calipers etc etc.
There is no modification needed, no cutting, no welding or drilling. Everything is a straight forward bolt on.
There is no need to swap out your Master cylinder or booster on these either.
You will have to upgrade or have upgrded wheels however to clear these, factory sedan wheels will not work. If you upgrade to the G37 sport 19" wheels, these will clear, or an aftermarket setup. Spacers are possible as well, depending on your overall setup.
As for aftermarket rotor/pads, etc... currently there is not much of an availability to choose from, but as soon as more aftermarket performance items beging to pop up for the G37Sport, We will begin offering them, integrated with this kit. Currently, this kit is as it stands, we are not able to swap out to drilled or slotted rotors etc...
And now, for the REALLY GOOD NEWS!, The Price:
$2000 +shipping!! For all 4-corners!
that's a true BBK for only $2000!!!
These are available NOW.
NOTE: These will not be compatable with older models unfortuantely, although we are working on a hopefuly adapter bracket for these calipers to fit onto the older Gs and Zs.
Please pm or call us with any questions you may have:
800-919-8130 tnazzal@riversideinfinti.com
and now for the pics:
Old May 15, 2008 | 10:11 AM
Wickster's Avatar
Save $150 buying used?
Old May 15, 2008 | 10:26 AM
B L U E S L A T E's Avatar
Honda Accord
WTH? Riverside Infiniti is selling this kit for $2250 for Christ's sake, and that's forum price, too.
Lou
Are you sure you didn't call some shady company in China?
I'll be **** pissed if Tony's selling these for $1800.
And $1550? Have you even seen the G37 BBK thread?!?! I cannot believe what I'm seeing in this thread. Jeez...
