FS/FT~CF KurumaZ Rear Diffuser
Old Jun 13, 2008 | 01:49 AM
  #31
Beebo's Avatar
Originally Posted by express705
do what i told you.
HES NOT SELLING IT ANYMORE. ANY ONE WHO WANTS IT GO AWAY.
you always do that crap... ahahaha
Old Jun 13, 2008 | 01:50 AM
  #32
Beebo's Avatar
Originally Posted by pghG35
does anyone have a DG 03-04 OEM REAR Bumper?..if so PM please thx.
you can also buy 05-07... they are all the same
Old Jun 14, 2008 | 11:50 PM
  #33
O HELLA OEM's Avatar
hey guys im goin to homedepot 2morrow to see if i can make a custom mold for that missing right piece
should i buy this
http://www.homedepot.com/webapp/wcs/...10000003+90106
and it saids i need to mix it with something but i dont know what..anyone have any input? thx
Old Jun 15, 2008 | 01:40 AM
  #34
anybody?...
Old Jun 15, 2008 | 10:06 AM
  #35
MikeYo's Avatar
link show a page error for me.
Old Jun 15, 2008 | 10:13 AM
  #36
Steel-Reinforced Epoxy Putty Stick
Epoxy putty sticks are the ultimate for small or emergency repairs. They are fast and easy to use, and bond instantly with superior strength. It is as easy as cut, mix, fix! This steel-reinforced epoxy putty stick is a fast-setting, industrial-strength polymer compound that enables permanent repairs to anything made of steel or other metals. It also bonds to wood, glass, masonry, and many plastics. Each handy stick contains pre-measured portions of activator and base throughout, so no measuring or mixing tools are necessary. As the epoxy is mixed, the two contrasting colors blend into one color to indicate complete mixing. The consistency (like modeling clay) eliminates drips and runs, facilitates adhesion to the substrate, and allows the material to be shaped and formed as needed before curing begins. It cures to a dark gray metallic color. Once cured, it can be tapped, drilled, screwed, sawed, machined, ground, filed, or painted.
Rebuild small engine parts, seal leaks, fill cracks & voids in metal, & fashion handles.
Belongs in every workshop & toolbox.
Form nuts and bolts, repair stripped threads & anchor machines.
Repair metal tools, equipment ducts, housing and appliances, & sink traps.
Works on anything made of steel or other metals.
Also bonds to wood, glass, masonry & many plastics.
The ultimate fix for small or emergency repairs.
Easy to use & mistake proof, just cut, mix, fix!
Bonds instantly with superior strength.
Saves hundreds of dollars in repairs.
MFG Model # : 600451070B
MFG Part # : 600451070B
Specifications
Assembled Depth (In Inches) : 1.2 In.
Assembled Height (In Inches) : 7.5 In.
Assembled Weight (In LBS) : .0625
Assembled Width (In Inches) : 4.25 In.
Chemical Clean-Up : Water, alcohol, mineral spirits
CircleEFriendly : N
Energy Star Compliant : False
Size (Oz.) : 2 Oz.
Product Reviews
Review and Rate Products
Share your opinion about products you\'ve purchased with others. Write reviews and rate products on a scale from 1 to 5. It\'s easy and takes only a few minutes.
Review Writing Guidelines:
Focus on the product features and your experience with them. Provide details about why you like or dislike the product.
Things to avoid:
Obscenities, discriminatory language, or other language not suitable for public forums
Advertisements, "spam" content, or references to other products, offers or Web sites
E-mail addresses, URLs, phone numbers, physical addresses or other forms of contact information
Critical or spiteful comments on other reviews posted on the page or their authors
__USERID__
http://www.homedepot.com/webapp/wcs/...0053&langId=-1
Product Reviews Review This Product
Warranty
Warranty
For warranty information on this product, please call our Internet Customer Service Center at 1-800-435-4654.
Old Jun 15, 2008 | 10:25 AM
  #37
MikeYo's Avatar
ehhh, Also bonds to wood, glass, masonry & many plastics. I'd look into that more before it does any further damage to the bumper or paint. None the less it going to be covered by the diffuser.
Old Jun 15, 2008 | 10:30 AM
  #38
then i guess ill get this one...
Fiberglass-Reinforced Epoxy Putty Stick
Epoxy putty sticks are the ultimate for small or emergency repairs. They are fast and easy to use, and bond instantly with superior strength. It is as easy as cut, mix, fix! This underwater repair epoxy putty stick is a fast-setting, fiberglass-reinforced polymer compound that enables permanent repairs to many surfaces including fiberglass, concrete, glass, metals, wood and many plastics. It is specially formulated to adhere to surfaces exposed to damp, wet or underwater (salt or fresh) conditions. Each handy stick contains pre-measured portions of activator and base throughout, so no measuring or mixing tools are necessary. As the epoxy is mixed, the two contrasting colors blend into one color to indicate complete mixing. It contains a fading blue dye and becomes white after mixing. The consistency (like modeling clay) eliminates drips and runs, facilitates adhesion to the substrate, and allows the material to be shaped and formed as needed before curing begins
Repair decks, hulls, pools, hot tubs, spas, marine recreational equipment, leaking gaskets, gutters & tanks.
Patch dings, holes & gouges.
Bond fiberglass, metal, wood, concrete, ceramic, glass & many plastics.
Specially formulated to adhere to surfaces exposed to damp, wet or underwater (salt or fresh) conditions.
Old Jun 15, 2008 | 10:36 AM
  #39
MikeYo's Avatar
Once you rebuild that area your going to have to let it dry for like 2 days of not more to make sure its rock solid before drilling it. I think if you put a good amount of the product, that it will work. Keep your fingers crossed!
Old Jun 15, 2008 | 07:49 PM
  #40
well i went to home depot ..thanks to mike haha..i bought the putty. i put it on like 40 mins ago..it said on the box it only needs 1 hour curing time..but im not goin to drill it anytime soon..b/c i dont have a drill anyway..i will take pics of how it turned out...
Old Jun 15, 2008 | 08:22 PM
  #41
MikeYo's Avatar
good luck. keep us updated.
Old Jun 15, 2008 | 08:50 PM
  #42
just snapped a few pics
damn that putty is rock solid..its super hard...
things are looking good!
Thanks Mike!! for the awesome idea...
The right side..
i filled in the left as well...
now all i need is to drill 2 holes and put my CF DIFFUSER ON!!!! cant wait..
Old Jun 15, 2008 | 08:59 PM
  #43
tragedycat's Avatar
this whole diffuser thing has been an ordeal for you, i've been watching the drama unfold over the past few days. im almost expecting your diffuser to go flying off on the highway. not that i'd ever wish for that to happen.
Old Jun 15, 2008 | 09:02 PM
  #44
thx i guess?..but the diffuser wont fly off(knockonwood)..theres two license plate screws and 4 bottom black clip things i clip on the bottom and theres 3M Double sided tape on the inside on the cf diffuser..so i dont think it will fly off..
Old Jun 16, 2008 | 12:58 AM
  #45
Beebo's Avatar
pghG35 im glad it all worked out
