Kinetix V++Plenum $250
Old Sep 10, 2008 | 01:12 PM
coolbratva's Avatar
Kinetix V++Plenum plus Z-Tube $300
Used for 3 weeks. Perfect condition.
Imrpoved in EVERY aspect over our previous intake plenum, including performance:
* 270% stronger than previous plenum
* Incredible heat resistance, improved 170%, now up to 500 degrees F
* Lower operating temperatures - 50 degrees cooler than ANY aluminum plenum option
* More volume! 20% more volume than factory and 12% more than our previous version
* Completely smooth underside with NO flow restrictions
* Can handle boosted cars, with lifetime warranty on cars up to 15 psi
* Lifetime Warranty
* Check out our upcoming "Upgrade Program" for our previous plenum customers!
This new intake plenum replaces the upper half of your factory intake manifold. This plenum bolts directly up to your car with zero modifications, and also allows the use of the factory strut bar, and engine cover. This unit will fit the 350z, the G35, and the FX. *** engine cover may not fit with the G35 or the FX35 **
This plenum increases the volume to the middle and more importantly the front cylinders. The factory plenum utilizes a very aggressive angle as it caps off the front cylinders. This new plenum equalizes the flow to all cylinders, while also increasing the total plenum volume. This plenum also uses a very versatile plastic to achieve a smooth interior for superior flow properties. The plastic also allows a lighter overall weight, by about 3 lbs. The overall temperatures of the plenum have also decreased by about 50 degrees farenheit. This helps with heat soak problems and to help lower air intake temperatures.
Our plenum has shown a solid peak gain of 14 rwhp and a consistent gain throughout the RPM range. When matched up with our high flow cats, they together have shown peak gains of 20 rwhp.
The plenum still retains all factory mounting points and also includes all necessary new hardware. The plenum also includes a permanently adhered flange gasket that is to be used with the factory gasket as well as a new throttle body gasket.
viciousbratva@yahoo.com
Old Sep 24, 2008 | 01:20 PM
coolbratva's Avatar
bump
Old Sep 25, 2008 | 01:48 PM
G35-M6's Avatar
have pictures of the plenum and z-tube on your car?
or do you have pics of the actual items? i hate looking at ebay pictures
Old Sep 25, 2008 | 03:15 PM
coolbratva's Avatar
I already took them off my car, but I can take pictures of actual items.
Old Sep 26, 2008 | 06:03 PM
D&G35's Avatar
how much for just the plenum shipped to 34210? i already have a ztube and i'm sure u can find sum1 who needs one..
Old Oct 6, 2008 | 11:57 AM
coolbratva's Avatar
$280 shipped.
Old Oct 6, 2008 | 01:36 PM
D&G35's Avatar
thanks for getting back to me..i already got a new one for 215 shipped..g/l man..
Old Oct 7, 2008 | 08:21 AM
Project's Avatar
y are you selling this if you just picked it up if i may ask
Old Oct 14, 2008 | 11:53 AM
draco0858's Avatar
i got a question. is this better than having a plenum spacer? thanks.
Old Oct 15, 2008 | 01:00 PM
ZoomZoom08's Avatar
Your mail box is full!
Old Oct 15, 2008 | 07:55 PM
TXaaron3232's Avatar
RICE LIGHTS FTL
Old Oct 16, 2008 | 01:59 AM
coolbratva's Avatar
Looking to install stillen supercharger.
Old Oct 16, 2008 | 02:00 AM
coolbratva's Avatar
It seems its a better choice if you look at the advantages of each product.
Old Oct 16, 2008 | 08:34 PM
Project's Avatar
ah i c
Old Oct 28, 2008 | 11:00 AM
coolbratva's Avatar
bump
