FS: Ings+1 Front lower Grill Ducts/Vents (Cut down/ mod project)
“ings+1” Front Lower Grill Ducts/Vents.(Cut Down/Good Mod Project)
I bought these from another G member but my painter FORGOT to put them on before moulding the lip on!!!!! I have to go a different route now. Here is the description from the original seller.
"Here's some pics of the ings+1 lower grill ducts. I attached them with double sided servo-tape. I cut them in half after I had my ings+1 front lip molded on, they wouldn't fit because the body shop mounted the lip too far up.
You can use the upper half like I did. Shown mounted on my G on the right in the 1st pic, or you can have them molded back together.."
The marks on the duct on the right are just tape adhesive. You can see that there were two in the first pic and only one in the second because I removed the first just before the camera died.
SOLD
They are on the silver G
Adrian
SOLD
Adrian
yes, it just sticks on the front with double sided tape.
Stock mesh stays, it just goes in front of it. You don't really notice the stock mesh because this sticks out a bit.
I was going to mould them back together and mould them into the bumper, but nnooooOOOOoooo - sheesh.
Thanks Hi-tech - now give me your front bumper
Adrian
Adrian
hey can u use this on a stock bumper ?
the ings lip just goes onto the stock bumper but these have to be put into the ducts before moulding on the lip b/c the corner overlaps. Since my painter did it the other way around, these wouldn't go on without ripping the bumper off and doing the mould over again!
can I say
any more!?thanks MX220 as well
Adrian
