FS: Everything you need for Manual 6mt Swap
Old Feb 9, 2009 | 12:20 AM
G35-31's Avatar
this for a rev up engine or regular one?
Old Feb 9, 2009 | 12:22 AM
rookie's Avatar
Trans parts wouldn't have really mattered rev up or not, besides the engine harness. He said 05 G, so should still be non rev up. I think. hahahah
Pretty sure the bulk of the parts have been sold.
Old Feb 9, 2009 | 12:55 AM
SDGeneralCounsel's Avatar
Originally Posted by ttrank
Wow, that is a good deal. The last guy I know who had one done cost him something like $9k.
well, the parts aren't the expensive part of the swap, it's the labor involved. OP, best of luck. I wish I could take this stuff off of your hands.
Old Feb 9, 2009 | 01:49 AM
Mr_pharmD's Avatar
I hope labor wont be more than 1500. THanks again for the parts Jason. GL with the g37
Old Feb 9, 2009 | 01:54 AM
rookie's Avatar
Technosquares quote is pretty accurate. Are you doing the ecu and cluster swap too?
Old Feb 9, 2009 | 03:16 AM
Mr_pharmD's Avatar
yes sir.
was that an issue when u did the swap?
Old Feb 9, 2009 | 03:20 AM
rookie's Avatar
I had no choice really, display on my cluster just shows blank. Better to be doing it the way you are doing so.
For your own good, verify the plugs are the same on the backside, ecu plugs should be the same within the same year ecus. Engine harness is going to be slightly different for the speed sensor on the 6MT, and clutch sensor so you can either have the car start with clutch depressed or just freely.
I have no CC currently, will try to get that working later.
Old Feb 10, 2009 | 12:37 AM
Mr_pharmD's Avatar
were u able to reuse your your AT engine harness? I checked with the MT harness and it fits the ecu. Is the harness suppose to hook up to the cluster also?
Old Feb 10, 2009 | 12:53 AM
rookie's Avatar
Engine harness from the ECU has lines going to the trans for both drivetrains. Interior harness may have little differences. 6MT has clutch pedal sensor, while 5AT has a parking brake sensor in that area. Little differences, plug the 6MT cluster in place of your 5AT and see what if it works.
The more you know about the changes the better off you are. Technosquare usually trusts me when we try something, I do lots o research. Still hit snags along the way but hey. I'm rookie.
Old Feb 10, 2009 | 02:30 AM
Mr_pharmD's Avatar
what kind of snags are u facing so I know what to expect.
Old Feb 10, 2009 | 02:33 AM
rookie's Avatar
Snags were for my freakshowcar. My firewall is not made for the clutch pedal assembly, I can't imagine your firewall being much different from a 6MT. Had to pull the vents running down the center console since 6MT is low, had to add handbrake not knowing if the stock one would work. Had no center console, had no mounting plate for the shift boot,
Little things, they figured it all out.
Old Feb 10, 2009 | 03:07 AM
Mr_pharmD's Avatar
that's good. I remember when I did the mt swap in my integra I was able to start the car without the clutch pressed in. How is ures setup? Can technosquare tune Vpro?
Old Feb 10, 2009 | 03:15 AM
rookie's Avatar
Mine is set up no need for clutch depress. No piggy backs for Technosquare. I'm tuned on the stock ecu. Had to run a 3" maf to keep from maxing it out, but it's draw through so drives like stock.
Old Feb 10, 2009 | 10:52 AM
Mr_pharmD's Avatar
nice, I rather have it setup without the clutch depressed too. One day I would love to see your ride in action.
Old Feb 26, 2009 | 12:24 PM
  #30
4drmadness's Avatar
pm me if you still have the VLSD
