FS: BNIB Griffin TuneFlex AUX iPod charger/cradle
Old Jan 25, 2009 | 08:48 PM
kamikazeiG35's Avatar
FS: Griffin TuneFlex AUX iPod car charger/cradle BNIB
*Brand-new in box* IPOD NOT INCLUDED
Item is located in the GTA (work in Mississauga).
Asking Price: $40 (sells for between $60 & $70 - plus tax - at both Futureshop & Best Buy - but they are selling the discontinued one) http://www.bestbuy.ca/catalog/prodde...9&catid=23080#
The perfect compliment to an already installed PAC AAI-NIS or USA Spec PA11-NIS unit!
Tired of your iPod just sitting in the cup holder? Let the TuneFlex hold your iPod for you!!
PRODUCT INFO
Mount, charge, and play your iPod in your car
If your car stereo has an AUX-In port, then TuneFlex AUX 2.0 is the perfect in-car solution.
TuneFlex cradles your iPod and holds it in the ideal position for easy (and safe) viewing and operation. Charges iPod as you drive and sends the sound through your car stereo's AUX-In port. TuneFlex AUX has the clean lines and ease-of-use of an expensive custom in-car mount for iPod, without the drilling, cutting and inconvenience of custom installations.
A new universal fit design includes a set of snap-on adapters to custom fit full-size iPod and iPod nano models. It's the ideal choice for households with multiple iPod models.
The unit plugs securely into the auto accessory port or cigarette lighter to charge and power iPod. TuneFlex's flexible steel neck is adjustable for maximum visibility of iPod screen and controls. The included 1/8"(3.5mm) stereo mini cable connects TuneFlex to AUX-input-equipped stereos for clean, interference-free sound.
Compatible models:
2nd gen iPod nano - 2/4/8gb
3rd gen iPod nano 4/8gb
Original iPod Touch - 8/16/32gb
iPod Classic - 80/160gb
iPod w/Video - 30/60/80gb
Griffin P/N: 9557-5GTFLXAUX-2
Features:
- Plugs into your cigarette lighter or accessory port to charge and power your iPod as you use it
- Included audio cable connects directly to car stereos with Auxiliary-in ports
- Flexible steel neck adjusts to almost any angle
- Built-in volume control
- Charging light changes color when iPod is fully charged.
Old Mar 18, 2009 | 11:50 AM
bump
Old Apr 2, 2009 | 11:36 AM
danielw's Avatar
where would it plug into on a g?
Old Apr 2, 2009 | 05:03 PM
You need a line-out from your stereo
I'm not sure about the newer models (I have an '04 coupe) but you need a line-out from your factory Bose headunit to plug into this cradle. The bendable arm goes into the lighter plug.
The easiest way to accomplish this is to install a PAC AAI-NIS2 unit or a USA Spec PA-11NIS unit, behind the stereo.
https://g35driver.com/forums/audio-v...-pa-11nis.html
It's a little transformer that allows you to take advantage of your unused SAT channel on the headunit and run your ipod through it.
Not too too expensive and not overly difficult to install.
Neither the PAC or USA SPec is included in this For Sale ad - I'm just selling the lighter adapter that acts as both charger and holder for your iPod.
Hope that helps,
Albert
Old Jun 3, 2009 | 04:54 PM
bump
Old Jun 29, 2009 | 12:40 PM
bump
Old May 4, 2010 | 11:38 AM
bump
Old May 4, 2010 | 12:46 PM
STCLAIRWEST's Avatar
Ill take it for 30, does it work with iphone?
seagrasser
May 3, 2022 09:43 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
stratous01
Oct 7, 2015 10:19 AM
dpark0223
Sep 11, 2015 02:17 PM
