Revup vortech kit!!!!!!!!
Old May 28, 2009 | 11:23 AM
Iron-Mike's Avatar
I know revup kits don't pop up often for sale but I don't see me installing mine in the near future so I'm considering letting it go to someone that can enjoy it this summer
the list below is everything I have bought or upgraded for this kit. There isn't anything that comes to mind that a buyer would need for this kit to make it run smoothly on their car. Its as complete as it could possibly get
I'm not sure how much to sell this setup for so I'm entertaining offers.
I have receipts for just about everything I bought since all is new still in the packaging except the emanage, vortech kit and the injectors
I can take pics tonight if anyone is interested
- revup SC trim vortech kit
(polished bracket, blower and all piping)
* kit is currently being polished so its unavailable at the moment for pics*
- Vortech 3.33 pulley
- GTM Machined 2.62 pulley
- GTM 28 Tooth Compressor Pulley
- GTM 32 Tooth Jackshaft Pulley
- 928 Motorsports boost limiter valve
(lets you control the boost level on a supercharger setup. ESSENTIAL for running this kit on a stock block. lets you dial down the 15-18psi to a more reasonable 8-10psi and have the boost come on quicker. can turn the boost up for built motors as well)
- 928 Motorsports V+ Impeller
(flows 15% more air than the T trim blower)
- HKS Race bypass valve
(louder than the stock BPV)
- NGK 1 step colder spark plugs
- Fuel pressure regulator
(has a gauge on it for adjusting fuel pressure and sits in the engine bay)
- Walbro 255LPH fuel pump
(in tank pump not the one that comes form vortech)
- Precision Turbo 525cc Fuel injectors
(high imepdence and flow matched set)
- Deatschwerks fuel injector clips
(needed to install the injectors)
- High capacity oil pan
(adds 1qt of oil to the motor)
- B&M Oil cooler
(larger than stock to keep oil temps low and prolong the life of the oil)
- Oil sandwich plate
(needed to use the larger oil cooler)
- 3/8" tap for threading the hole for the oil return line
(seems to be a hard tap to find and doesn't come with a vortech kit from the factory)
- emanage ultimate with boost sensor and plug and play harness
- magnetic drain plug for the oil pan
Old May 28, 2009 | 12:23 PM
hextacy's Avatar
2500.00?
Old May 28, 2009 | 12:57 PM
gabe3d's Avatar
^ ... come on man, don't low ball him.
If I had a revup I'd make you an offer, good luck with the sale.
Old May 28, 2009 | 01:30 PM
Iron-Mike's Avatar
Thanks for the well wishes I appreciate it!
Old May 28, 2009 | 01:31 PM
Iron-Mike's Avatar
Originally Posted by hextacy
2500.00?
you can't possibly be serious so we'll just pretend you didn't just post that
Old May 28, 2009 | 01:58 PM
Aptos936's Avatar
How 'bout adding up all your receipts, discount by 15% or 20%.
Easier than asking everyone to take a SWAG at what it's worth to you.
I might even go for it..
Old May 28, 2009 | 02:01 PM
Iron-Mike's Avatar
ok how about $4k OBO then... lets start there and see where things end up
Old May 28, 2009 | 03:03 PM
Bobyl573's Avatar
would you be willing to part out injectors and oil stuff? if this was for a nonrevup i'd take the whole thing haha
Old May 28, 2009 | 03:07 PM
str8dum1's Avatar
what happened? the big install day is only like a week or so away! don't sell!!!
you'll be the 1st to use the 928m impeller and have results from it!
strap that sucker on your car!
Old May 28, 2009 | 03:14 PM
Iron-Mike's Avatar
I simply don't have the time to install it or anything. So as much as I'd like to do it I'd rather sell it than keep it in a box in the closet or something until God knows when
on a good note I've done all the legwork and sourcing for a potential buyer. Kit requires nothing extra to make it run so its as complete as anyone could possibly hope for
Old May 28, 2009 | 03:17 PM
GreenGoblin's Avatar
The goblin resurrection
Install is the easy part, come back down on vacation and I will install it for you.
Old May 28, 2009 | 07:24 PM
6MTFTW's Avatar
PM Sent.
Oh yeah. Which version is this? V2 or V3?
Old May 28, 2009 | 07:29 PM
Iron-Mike's Avatar
Originally Posted by 6MTFTW
PM Sent.
It's a V2 which is why I bought so many cooling upgrades for the kit. The V2 kit shares oil with the engine
Old May 28, 2009 | 07:45 PM
Chef-j's Avatar
WOW many good stuff!! Good luck!
Old May 28, 2009 | 07:47 PM
hextacy's Avatar
whish i had 4k....
