Wheel Bearing
Old 06-08-2009 | 04:07 PM
Shawn87's Avatar
Wheel Bearing
SOLD
Bought a wheel bearing for my coupe and turns out my wheel bearing is fine
After tax this is $280 bucks...
2004 Coupe Wheel Bearing
Old 06-08-2009 | 04:16 PM
DNG35's Avatar
I just did the exact same thing. Is your car making a sound in the front.
Old 06-08-2009 | 04:19 PM
Shawn87's Avatar
Ya, and I thought it was a bearing... I took it to Vic's and apparently its just a sound that comes with the car, because it happens sometimes if you rev it. Steve said it was something to do with the detonation. :S
What am I going to do with a wheel bearing now haha.
Old 06-08-2009 | 04:24 PM
DNG35's Avatar
naw see mine is making a scraping noise like a ssshhh shhh shhh shhh every time the wheel goes around. i thought obviously its a bearing. changed it. It wasnt, now i have to figure out what it is.
Old 06-08-2009 | 04:27 PM
Shawn87's Avatar
Oh that sucks... is it lowered? I found out the shop who put my lowering kit on didnt put the sensor spacers in, and guess what, they got the sh*t rubbed outta them, but thankfully still work! 300 each for those suckers.
Old 06-08-2009 | 04:30 PM
DNG35's Avatar
no its not lowered...i gotta bring it in..i just cant justify bringing it to infiniti and letting htem charge me a million. I'm out of warranty so i dont know. I might just bring it to the deal just because they know the car the best.
Old 06-08-2009 | 05:09 PM
Jasonp32's Avatar
Exact same thing is happening to me right now. It's coming from the rear passenger side. It crossed my mind that it could be a bearing, because the sound only happened after turning right, then it would stick around until I hit the brakes. I've had the car for a year, 10000kms, so I figure my brake pad is toast. Already ordered a full set and plan on taking that caliper off this weekend. Check your rotors for grooves.
Old 06-08-2009 | 06:38 PM
evolver's Avatar
Any chance it could be tire noise? Some tire brands make once worn a bit make noise that is hard to tell apart from wheel bearing noise. Sound patterns are very similar.
Old 06-08-2009 | 07:13 PM
rickyk's Avatar
i have something like you guys .. when i go over 80 km i hear a noise coming from the front driverside wheel like its pulsating .. and when i turn it to one side it quickens and when i turn to an other it slows down.. i heard that infiniti over tighten the hub bolt or something..maybe that ...anyone elese have the same problem ? oh and my front driverside tires have un even ware on them from it same with my snow tires
Old 06-08-2009 | 08:17 PM
DNG35's Avatar
yah i have old snows on there right now so hopefully its just the tires making the noise. I changed out my bearing assembly and i just put new rotors and pads so it cant be that. The only variable that remained the same were the tires.
Old 06-08-2009 | 10:21 PM
Shawn87's Avatar
My sound is definitely an engine sound... but if you think your sound is a wheel bearing I have one for CHEAP!!! lol
Old 06-08-2009 | 10:41 PM
Jasonp32's Avatar
Can't you just return it and pay a 20% restocking fee or something? But don't do it yet! If I'm wrong about my car I might need that bearing after this weekend!
Old 06-09-2009 | 07:42 AM
Shawn87's Avatar
I hate dealerships...
Let me know!
Old 06-09-2009 | 04:11 PM
randy021186's Avatar
SO TRUE, i diagnosed by standing outside the car while my friend drove up and down the block, in the car it sounds like a bearing problem, outside it sound like tire rubbing or the e-brake is up
Old 06-11-2009 | 07:40 AM
Shawn87's Avatar
Bump!
Quick Reply: Wheel Bearing
