Feeler: Complete double-din kit w/ Pioneer AVIC-F90BT
Jun 26, 2009 | 11:11 AM
Yes, I installed it myself. And, as I've said before:
Quote: The only thing I can think of that you'd need is the bracket (IIRC, you can use your factory bose bracket. Don't quote me, though).
Quote: I've been getting a lot of the same question, so I'll try to answer it as clearly as I can. (I also made it bold in my original post).
The only thing that you MIGHT need to install this in your car is the mounting bracket. However, I'm pretty sure that you can re-use your existing Bose bracket. I'm ont 100% sure, though. You need to research and confirm this for yourself.
Jun 26, 2009 | 08:02 PM
Scratches on the screen? Pics aren't helping you sell it....maybe clean it up, take a pic with it off, and one with it on (to show that it works, and doesn't have scratches). Very interested.
Jun 27, 2009 | 04:38 PM
Update: Bracket is now included, as well as antenna adapter. I just removed it from my car and remembered that, if you want the steering wheel adapter to work, you need to splice/solder in two resistors. The instructions can be found on the PAC-Audio website.
Also note, that the hardwire bypass has already been performed. You can view movies and/or have full control of every function while the car is in motion.
Everything that you see is included; AVIC-F90BT, GPS antenna, antenna adapter, microphone, PAC-Audio steering wheel controls, wiring harness adapter, bracket, IPod adapter, stylus, JDM Double-Din finisher, JDM DUAL AC controls, original packaging and instructions.
Jun 28, 2009 | 08:33 PM
Sold!!!!
Jun 28, 2009 | 08:50 PM
SOLD! Looking forward to taking on this challenge.
